It is currently Sat Oct 24, 2026 7:57 pm
 Post subject: Odd UK loco
PostPosted: Tue Jul 22, 2003 2:21 pm
Can someone identify this engine, said to have worked at British Oil and Cake Mills in Kent?
http://abpr.railfan.net/abprphoto.cgi?december02/12-17-02/BOCM-St_Vincent2-ER-101260.jpg
ryarger@rypn.org
 Post subject: Re: Odd UK loco
PostPosted: Tue Jul 22, 2003 2:24 pm
This photo says made by Aveling & Porter. I assume this is the same firm that produced steam tractors and road rollers? Do any of these still exist?
http://abpr.railfan.net/abprphoto.cgi?december02/12-17-02/BOCM-Sydenham1-ER-101260.jpg
ryarger@rypn.org
PostPosted: Tue Jul 22, 2003 5:00 pm
Can't help you with info on these engines Bob but they're were some pretty interesting engines used by Guiness in Ireland. 0-4-0 narrow gauge engines that could be lifted and dropped into a broad Irish gauge contraption (almost like a cradle) that transferred the power from the wheels of the narrow gauge engine to broad gauge. Don't know if any of those survived.
Joshua
joshua@joshuakblay.com
PostPosted: Tue Jul 22, 2003 5:08 pm
It is the same firm that made the Road Locomotives. There is at least one preserved in the UK.
My questions are, how do you get a single cylinder locomotive moving if the piston is at the extreme of the stroke and on level ground? How many firms made single cylinder locomotives?
Very interesting little creature.
Roger
belpaire@aol.com
PostPosted: Tue Jul 22, 2003 5:21 pm
Looks more like a compound than a single cylinder?
If so It's probably quartered like a stationary or marine engine
PostPosted: Wed Jul 23, 2003 9:24 am
I had considered that until I read the following description about another Aveling Porter: 'It was of 0-4-0 wheel layout with a single over-type cylinder driving in typical traction engine manner through an open gear-box with sliding gears and a gear-wheel meshing with cog wheels fixed to the inside the right-hand driving wheels of both axles'. That seems to fairly well describe the layout of the ones shown. I would assume (you know what happens when you assume) that it is a piston valve locomotive and that is why there are two different size cylinders.
As for the Guinness locomotves mentioned above, there are at least 5 of these 18" gauge engines still in existance.
Roger
> cylinder?
belpaire@aol.com
PostPosted: Wed Jul 23, 2003 9:48 am
OK, next question: what's the purpose of the connecting rods attached right to the axles?
PostPosted: Fri Jul 25, 2003 3:50 pm
They are not connecting rods, they are tie bars.
The wheels are connected to the cylinders by a gear wheel set between the driving wheels. It thus tends to push them apart. The "rods" are maintain correct spacing.
Only a small number of these locos were built. They used traction engine technology.
jimlivesey@btopenworld.com
