It is currently Sat Oct 24, 2026 11:12 am
 Post subject: How many UP GP9 B units remain?
PostPosted: Sat Aug 10, 2019 12:17 am
I've been wondering for some time about just how many Ex UP GP9 B units remain like this rebuilt example? This B unit became one of the GP10 locos built by the Paducah Kentucky shops. https://www.youtube.com/watch?v=dUEl9IkNmM4
Robert
 Post subject: Re: How many UP GP9 B units remain?
PostPosted: Tue Aug 13, 2019 12:53 pm
Not a bad vid, but don't like not seeing the compression relief/cylinder purge valves open for a couple revolutions to make sure the engine doesn't get hydro-locked from a leaking exhaust valve or injector. Hopefully it was just cut to save time.
PostPosted: Tue Aug 13, 2019 3:53 pm
Is that not what the description mentions? Sounds similar, so I believe so.
PostPosted: Tue Aug 13, 2019 3:55 pm
It does mention it was done in the description, but it is getting rare that RR guys do blow downs anymore. Most railroads don't even teach it.
PostPosted: Tue Aug 13, 2019 9:00 pm
I've run that unit many times... It was built as a B unit for UP, but I don't reca!l the original number right now...
As to the start up....I have noticed many places no longer teach that, not sure why...I have heard something to the effect of "the engine is too worn to bother or care"....seems a bit odd to me, sounds more like laziness or time saving....
PostPosted: Tue Aug 13, 2019 10:17 pm
I read some where that you should blow down the cylinders if the engine has been off for over two hours.
PostPosted: Tue Aug 13, 2019 10:41 pm
The common rule of thumb in the marine world is 5 hours. With the exception of our FM, we do it every single time. Its 5 extra minutes.
PostPosted: Wed Aug 14, 2019 9:41 am
The poster of that video mentioned that in the interest of time and editing, he did not include the opening of the relief valves and blowing out any water. It was all right there-
PostPosted: Wed Aug 14, 2019 8:41 pm
How many actually use the barring jack to roll the engine over instead of the batteries? I use it when we haven’t run the FL9 for a while. If it was run relatively recent, like the day prior, I’ll use the batteries.
Randy Patterson
RMNE/NAUG
