It is currently Sat Nov 21, 2026 1:37 am
 Post subject: Parts sw1
PostPosted: Mon Jul 29, 2019 9:43 pm
Wanted to offer sw1 parts for sale 6-567 UC prime mover (this has water jumpers in the air box like the later straight C blocks) main gen. traction motors d17 d27 let me know your needs would be happy to pull spacific parts
Update on possible frame number looks to be 7 A where builder plate was
Not sure what orange paint was other then Illinois Central Gulf.......just a guess
 Post subject: Re: Parts sw1
PostPosted: Tue Jul 30, 2019 2:05 am
Where’s the unit located? Does it have a linear throttle or the conventional 8 notch throttle?
Sam
PostPosted: Thu Aug 01, 2019 6:26 pm
Linear it is in the north east
PostPosted: Fri Aug 02, 2019 1:11 pm
Still interested in the oil cooler if it is available. Would like measurements to make sure it is the right size.
PostPosted: Fri Aug 02, 2019 9:14 pm
Is a headlight from either end available?
PostPosted: Tue Aug 06, 2019 9:16 pm
What shape is the water tank in? Do you any photos?
Thanks,
Mike Tillger
PostPosted: Mon Feb 03, 2020 11:12 pm
If it has the origenal handbrake this guy is looking viewtopic.php?f=2&t=43544
PostPosted: Thu Feb 06, 2020 1:50 am
Does your SW1 have any of the class light parts?
PostPosted: Sun Sep 27, 2020 11:38 pm
8-5-2021 update
Aux gone
Fan parts gone
Load reg gone
Headlights gone
Handbrake gone
14 brake stand gone
Ground lights gone
Pain bearing (friction) thrust shims gone (all)
Have 6 k valve SOLD
Have plain bearing (friction) brass/ full set available
Brass thrust endplate 6 available
Still for sale tm 1 d27 2 d17
Prime mover 567 UC
Main gen megged ok
Compressor
Cast locomotive bell also available if interested
Air brake parts left
Strainers/filter
equilizing res.
Valve and bracket T9102 (marked)
(Happy to send pictures if interested)
Trucks and wheels at right price
Let me know your needs
PostPosted: Sat Nov 07, 2020 2:48 pm
One serviceable coupler
PostPosted: Thu Nov 26, 2020 4:52 pm
Sent you a message about the bell
PostPosted: Sun Jul 25, 2021 2:31 pm
BTT
PostPosted: Mon Jul 26, 2021 4:28 pm
Plain bearing, I assume?
Andrew Durden
Chief Mechanical Officer
Southeastern Railway Museum
PostPosted: Mon Jul 26, 2021 10:08 pm
Correct I think that is in the 4th post back, are you interested? They are from 67 if I recall
PostPosted: Fri Oct 01, 2021 5:52 pm
Update....Most of the brake valves are gone strainers are left equilizing res. Valve and bracket T9102
List updated
