It is currently Mon Oct 19, 2026 10:06 pm
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Fri Jul 05, 2019 1:01 pm
Thanks, Kelly, Fabulous!
I always note when I visit the Strasburg shop that the machines are clean, oiled, have a cutting tool chucked up, and usually a work piece in the vise/clamps.
When I visit "other" railroad shops, they have machine tools, but most often they are dusty, have no cutting tools, and no workpieces.....ie they are seeing very little to no use...….
PostPosted: Fri Jul 05, 2019 2:03 pm
The places with dusty, dirty machine tools almost never have a machinist on staff or even a volunteer. And if they don't have a machinist, they also don't do much mechanical work on their rolling stock. It's a fact of life at most museums.
PostPosted: Fri Jul 05, 2019 6:47 pm
.......even though #475 can be a back breaking bitch to run in hot weather.
Or cold weather, or wet weather, or dry weather, or windy weather.......
Ergonomics was not on the drafting table.....
PostPosted: Sat Jul 06, 2019 8:53 am
Thanks Kelly, always my favorite part of this board are your updates. VERY impressive work on that firebox door opening.
PostPosted: Sat Jul 06, 2019 10:24 am
'Well, actually according to Whyte, 4-8-0's are "twelve wheelers". 4-10-0's are "Mastadons", and about as rare as well. Never the less, I agree that the N&W 4-8-0's are eye candy for steam fans, even though #475 can be a back breaking bitch to run in hot weather.'
I totally screwed that up! Thought I was so smart too! She's still a fav though. Ned
PostPosted: Sat Jul 06, 2019 12:31 pm
Kelly - Thank you for taking the time to post this. These updates remain one of the best features of RYPN. Looking forward to seeing the shop - one of the few truly active steam shops as pointed out by fairmontdave - during the 611 event.
A question about boilermaking and industry business practice - Can the male and female dies SRR fabricated to press the O'Conner firebox door hole for 3713's new fire box be reused? If so, does SRR retain the dies, scrap them, or send them to the customer with the firebox in the event a new fabrication is required in the distant future?
PostPosted: Sat Jul 06, 2019 12:56 pm
nedsn3 wrote:
Thanks Kelly! Love those N&W Mastadons. Too bad nobody has an SP 4-10-0 running.
You mean the 4-10-2’s like SP 5021? Because even in America, the 4-10-0 is probably the rarest made Wheel arrangement in the US, and it’s a bit weird to talk about 1 engine.
The only 4-10-0 was built for the SP predecessor Central pacific in 1883, named El Gobernador, but it was deemed a failure and scrapped a decade later.
PostPosted: Sat Jul 06, 2019 10:04 pm
Good point. The SP had 4-8-0s as well, one of which (SP 2914) is now the only surviving non-N&W 4-8-0 in America.
Richard Jenkins
PostPosted: Sun Jul 07, 2019 2:24 am
I'm too late to second that, so I'll just echo others! You guys (and gals) are simply amazing! Strasburg's Steam Gods! Would make for an interesting topic for a Discover Channel series.
Thanks for sharing!
/Mitch
PostPosted: Sun Jul 07, 2019 3:17 pm
Last edited by Kelly Anderson on Sun Sep 29, 2024 5:14 pm, edited 1 time in total.
PostPosted: Sun Jul 07, 2019 4:21 pm
Kelly - meant to ask - with regards to the photo of Jim is cutting the keyway into the axle hole using the slotter:
What are the square "holes" seen on the driver rim? Assume the wheels are cast - looks as if the spokes are hollow??
/Mitch
PostPosted: Sun Jul 07, 2019 4:36 pm
Kelly Anderson wrote:
Thanks, but please. Also, I do make a point of not posting photos of our foul ups.
SRC may look like a duck gliding across a still pond from outside, but I assure you that under the surface, we are paddling like mad.
and that speaks volumes for your integrity
PostPosted: Mon Jul 08, 2019 8:15 am
PostPosted: Mon Jul 08, 2019 9:14 am
The door hole is a for a Standard HT stoker. If anyone is looking for a spare door hole of this configuration, we have one stamped in a piece of pv quality plate that I made to test the process before stamping the already flanged sheet. I’m sure we could work out a deal.
Brendan Zeigler
Vice President - CMO
Strasburg Rail Road Co.
brendan.zeigler@strasburgrailroad.com
PostPosted: Mon Jul 08, 2019 4:02 pm
When I first saw inside this engine's cab I could not figure what was in their mind to buy this pile of junk. Seat positions crammed in, firebox door level, no deck to work on. One thing was for sure they didn't give a crap for the crew that would have to work in it.
