It is currently Mon Oct 19, 2026 10:24 pm
 Post subject: EDNA A 820 Lubricator
PostPosted: Thu Jun 06, 2019 9:49 pm
Hi all,
A&WP 290 has the above reference lubricator for steam valve and cylinder lubrication. I am looking for manuals on the lubricator. Due to good intentions and not following up, I believe some parts are missing on the oil seals of the ratcheting shaft. I have digital Nathan manuals, but they are unlike the EDNA, as far as I can figure. Any help with copies or digital scans would be appreciated.
Thanks,
Dale
 Post subject: Re: EDNA A 820 Lubricator
PostPosted: Fri Jun 07, 2019 5:20 pm
Dale Grice wrote:
Hi all,
Thanks,
Dale
I know you are looking for a detailed manual, hopefully someone will step forward with one. I love dong internet searches for this sort of stuff, but the best I could find is this listing of an Edna publication from 1945, available at certain libraries:
https://www.worldcat.org/title/quality- ... /300300074
I did find out that Edna Brass Mfg. Co. is a Superfund site in Cincinnati now occupied by a casino. I also found that the Carson & Colorado did a total rebuild on their Edna lubricator on #18 twenty years ago: https://carsoncolorado.com/history-of-1 ... ssessment/
"Hydrostatic Lubricator (for piston and compressor lubrication): Edna #9 three-feed. The lubricator was completely gone through in 1999 and had some sight glasses and all gaskets replaced. While untested, it should be in ready-to-use condition and not need additional work."
Not much to go on, hopefully someone will step forward with more practical information.
PostPosted: Fri Jun 07, 2019 7:53 pm
Railway Locomotive Maintenance By F. E. Kardes Published by American Technical Society Part 4 has information on Edna mechanical lubricator Model A 624 which may have what you need . TRAIN might have reprinted it back in the 1980s.
Hope this helps
Dennis Daugherty
PostPosted: Fri Jun 07, 2019 8:04 pm
Hope this helps
Dennis Daugherty
https://www.worldcat.org/title/railway- ... lc/3230449
PostPosted: Sat Jun 08, 2019 1:41 pm
Mr. Grice, check your new messages, I sent you a PM.
PostPosted: Sat Jun 08, 2019 10:29 pm
Mr. Grice, check your e-mail.
PostPosted: Mon Jun 17, 2019 1:42 am
Did you get the information I sent to your personal e-mail on June 8th? If my e-mails are not reaching outside my out box, I need to find out why.
PostPosted: Mon Jun 24, 2019 2:42 pm
Thank you all for your replies. I learned what I needed.
Adam, I did get your email. - Thanks
