It is currently Sat Oct 24, 2026 2:33 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
 Post subject: A bad day for SP #18
PostPosted: Tue Apr 09, 2019 8:10 pm
Narrow Gauge SP 4-6-0 #18 on loan to the Durango and Silverton blew a cylinder head, ...she’ll be out for a while.
Last edited by Finderskeepers on Tue Apr 09, 2019 8:15 pm, edited 1 time in total.
 Post subject: Re: A bad day for SP #18
PostPosted: Tue Apr 09, 2019 8:14 pm
Another view
PostPosted: Tue Apr 09, 2019 8:39 pm
My goodness! I hope no one was hurt.
Any idea as to what happened, or is it too early to say?
Greetings from Alberta
-an Articulate Malcontent
PostPosted: Tue Apr 09, 2019 9:31 pm
That's unfortunate. Looks like a nice clean break in the casting. No clear sign of a prior crack/flaw.
Looks like a hydraulic failure, someone forgot to open the cylinder cocks, or the cocks were plugged ?
Good luck, Kevin
PostPosted: Tue Apr 09, 2019 10:02 pm
Good luck, Kevin
I'm thinking if it had been water in the cylinders it would have blown the entire head off. I'm thinking something else let go and the piston overtraveled into the cylinder head.
PostPosted: Tue Apr 09, 2019 10:11 pm
https://durangoherald.com/articles/2716 ... of-durango
PostPosted: Tue Apr 09, 2019 10:16 pm
Looks like the piston came loose and hit the head....very similar to the damage incurred on the hiesler that was running in Arizona in '09...rod end came off, piston hit the head, blew the cover off and shattered the head....
If you look close, there's probably cracks radiating from the center hole....
PostPosted: Tue Apr 09, 2019 10:22 pm
Whatever happened, it does not look as simple as someone forgot to open the cylinder cocks. Looks like the piston itself shattered as well as the head...appears something worked loose allowing the piston to contact the cylinder head.
PostPosted: Tue Apr 09, 2019 11:30 pm
Well, if it had to happen it happened at a railroad with a shop more than capable of dealing with this kind of relatively simple repair. I'm sure the D&S will have her back in service soon after they get the castings from the foundry.
PostPosted: Wed Apr 10, 2019 8:53 am
That's not something you see everyday even in the steam era. However in today's world it is a WOW event.
PostPosted: Wed Apr 10, 2019 12:25 pm
The piston fragments show that they struck each other as the thing disintegrated, and that tells me that the cylinder bore got gouged and roughed up by those big chunks as they hammered the cylinder head.
I see a boring machine in that engines future.
PostPosted: Wed Apr 10, 2019 12:55 pm
This thread on the NGDF contains a number of images showing the damage, etc.:
SP 18 run, piston failure, and rescue 4-9-19
PostPosted: Thu Apr 11, 2019 1:22 am
I was riding this train during the break down. Official cause was a broken lubricator.
PostPosted: Thu Apr 11, 2019 3:41 pm
Surprised they've nailed it down so fast. However, I suppose the lack of lubrication could have caused the piston to bind up, which caused it to slide on the piston rod or do something that effectively made the piston rod longer than it should be by moving some adjustment point. That could in turn cause it to strike the cylinder heard. So it's seems plausible that's what happened.
PostPosted: Thu Apr 11, 2019 4:35 pm
Per Jeff Taylor post on NGDF...
"Here is the inside scoop. It is believed that a partial ring failure caught a port and destroyed the piston. The piston fragments then punched a hole in the cylinder head."
More information can be found at their forum.
