It is currently Thu Nov 26, 2026 12:29 am
 Post subject: 25t GE builders plate question
PostPosted: Wed Mar 06, 2019 12:08 pm
Ok, have the 2 new builders plates being done for our GE 25tonner. However, need some assistance with a few numbers. THe shop doing the plates is going to print the numbers right onto it, instead of us using the number punch. Will of course make it stand out more, and make it very readable.
Found this plate on line, ours will be similar, but my question is do the numbers on the CLASS line all match for any 25tonner? Ours is, as far as we know, original, except for a train brake being added. I just want to make sure the correct numbers go in that spot.
Any help is appreciated.
Ken Jones Jr.
http://www.nfrm.ca
 Post subject: Re: 25t GE builders plate question
PostPosted: Wed Mar 06, 2019 12:25 pm
Would be similar or, the 733 is traction motor model number installed in the locomotive. You will need to climb underneath and check the data plate on your unit to verify.
The way the number system in the early switchers works is:
B-50/50-1GE733 =
--Axel Arrangement - B meaning 2 powered axles in the same mounting assembly (whole locomotive is considered a truck in your case, whereas a 44 tonner is BB-88/88 as it has 2 trucks both of which have 2 powered axles)
--Weight on axle groups in 1000 lbs - 50/50 thus 25 tons on either axle
--# of traction motors - 1
--model of traction motors - GE733
Never understood the weight part but that is how it was explained to me
25 tonners are 50/50
30 tonners are 60/60
44 tonners are 88/88
45 tonners are 90/90
Your serial # should be stamped near the striker plate in the engineer's door frame and on the front or rear frame member next to the coupler.
Rich C.
PostPosted: Wed Mar 06, 2019 12:28 pm
That's perfect, excellent breakdown, thanks so much Rich.
Ken Jones Jr.
http://www.nfrm.ca
PostPosted: Wed Mar 06, 2019 1:24 pm
We have a 23 ton GE switcher. Can you tell me where the builder's plate is located? Thank you
PostPosted: Wed Mar 06, 2019 1:51 pm
The two numbers represent the weight on drivers and the total weight in thousands of pounds. Not totally sure which is which.
Why the two numbers? Probably because some of the mainline straight electrics had un-powered lead axles or trucks. But, I have yet to see a plate from one of these.
PostPosted: Wed Mar 06, 2019 2:09 pm
Well, on ones i've seen, usually on the side of the cab. Ours are missing, but they obviously painted the engine before taking them off. In the pic, you can see where it was by the brown rectangle at the down left corner of the cab.
Ken Jones Jr.
http://www.nfrm.ca
PostPosted: Wed Mar 06, 2019 3:33 pm
IIRC on our 25 tonner, the engineer's plate was also in the front corner, but I have a photo of one of her sisters where the fireman's plate is in the rear corner. Best to look for the 4 holes, they used drive screws in the 4 corners, so you will have holes between 1/8" to 3/16" diameter. If they have been filled they might be easier to see from the inside since there is usually only 1 layer of wall metal, and they probably didn't grind the interior smooth afterwards.
if you need some:
https://www.mcmaster.com/drive-screws
PostPosted: Wed Mar 06, 2019 4:52 pm
Hi-Where did you find it online? Please post the URL
Thanks
PostPosted: Wed Mar 06, 2019 6:39 pm
Site Admin
The plate on our 25 ton GE is mounted on the frame, under the fireman's side of the cab. It is possible that it was moved there, as we have photos of the locomotive after an accident laying on the fireman's side.
Our plate reads:
B-50/50 – 1GE 733 150HP
18139 Dec 1943
TG1872 21547
DN 153126
This locomotive came to us from the Nevada Test Site, where it was used on the "Jackass & Western" railroad, located on Area 25. The railroad was used as part of the Atomic Energy Commission (AEC) and NASA's project Rover, , later called Nerva, to build a nuclear powered rocket for travel to Mars...
Randy Hees
PostPosted: Wed Mar 06, 2019 6:54 pm
Ask Dan V. from Port Stanley Terminal Rail Ken. Their 25 tonner has a plate on it in the same location as yours.
PostPosted: Wed Mar 06, 2019 10:08 pm
The numbers you will find stamped above the coupler pocket on most GE industrial diesels are not the GE serial number. Those stampings are the "Batch Number," from which can be deduced the serial number--if you have the cross-reference. (I don't.)
The place where I have often found the serial stamped is UNDER the builder's plate. This area is often rusty and pitted and reading the serials can be difficult, especially if the stamping is shallow. In 2013 Pennsylvania Trolley Museum acquired a damaged 25 tonner and scrapped it for parts for our loco 89, which we converted from standard to broad gauge (62.5") for use at PTM. In the course of scrapping the parts loco I cut off a piece of the cab where the builder's plate had been. The serial turned out to be 29900, but the way it was stamped it could be read many different ways, as only the 2 was easily recognized as a 2, the last 4 digits could have been 3, 6, 8, 9, or 0 the way they were stamped.
I will examine our loco for any stampings around the door latches.
PostPosted: Thu Mar 07, 2019 12:22 pm
Ken,
Cross referencing the information on your web page, with GE Record sheets:
S/N 29231 shipped 8-Jan-48 to Iroquois Construction Ltd, Cornwall, Ont.
Shipped with a 1503 Main Generator, 733 Traction Motor, and HBI-600 engine.
S/N 29231 was apparently rebuilt and shipped in 1959, to Shawinigan Chemical Co, Shawinigan, Que.
Specifications the same as above.
JR
PostPosted: Thu Mar 07, 2019 3:27 pm
As I mentioned in an earlier post, the yellow 25tonner is ours, and someone had mentioned to look for the holes. In our case, they are where the unpainted section is on the cab. John Redden, thanks for the rebuild info. We had the history of the unit, but not that part, good to know. I thought I saw somewhere online in one of my google searches for GE 25 tonner, the plate was in the middle bottom of the cab. Could be wrong though.
As for the plates, all the pertinent info is being printed right onto them. I look forward to seeing the proof, and of course, the finished product. I'll share an image when they're done.
Ken Jones Jr.
http://www.nfrm.ca
PostPosted: Fri Mar 08, 2019 9:27 am
"Ken: Cross referencing the information on your web page, with GE Record sheets:
JR"
John:
I own a 25 tonner, S/N 27614. Could you provide the above info from the GE record sheets to my unit? I don't know much about its' history. Or, is that info available on-line somewhere?
Thanks!
PostPosted: Fri Mar 08, 2019 1:52 pm
As far as I know, the details are not available on line. I have a book of photostatic copies of GE locos (actually covers several books). I am temporary custodian, on behalf of a museum.
27614 - 25 Ton, Shipped 24-Jul-44. Natchez, Urania, & Rushton RR, Urania, La. It has a handwritten notation "2d Owner. Orig. Naval Ord. Tstg Stat, Inyokern, Cal."
This is unusual, in that most listings have a distinct chronological order, with the original owner on the first page, next page with the second owner, etc.
It lists M.G. as 1503, T.M. is 733, and engine is HBI-600
2nd page - 27614 25 Ton, Shipped 1968 Urania Lumber Co. LTD, Urania, La.
1503, 733, HBI-600(3) Not sure what the (3) indicates.
I gather that there was some misprint in the sheets, and the loco most likely went to Naval Ordinance Testing Station, in Inyokern Ca. in 1944, and apparently went to Urania La. in 1968.
