It is currently Sat Oct 17, 2026 11:27 am
 Post subject: Re: Metropolitan Injector Info
PostPosted: Mon Jan 21, 2019 11:32 am
Last edited by Kelly Anderson on Mon Sep 30, 2024 4:51 pm, edited 1 time in total.
 Post subject: Re: Metropolitan Injector Info 2H Tag
PostPosted: Mon Jan 21, 2019 1:05 pm
Porter 2H tag.
PostPosted: Mon Jan 21, 2019 9:09 pm
Kelly, Have you tried Farmers Copper for copper pipe? As recently as last summer we bought 1/2" schedule 80 from them.
PostPosted: Mon Jan 21, 2019 9:37 pm
Availability of thick walled copper pipe has also been a challenge for live steam model boiler builders.
PostPosted: Mon Jan 21, 2019 9:49 pm
These Metropolitan injectors are similar to the Hancock "inspirators". They are fundamentally different from the Nathan/Sellers injectors in two ways: the water feed and the mechanical valve connection on the overflow to the starting handle. On a Nathan/Sellers, the lower valve is a water stop valve. On a Hancock, the lower valve controls the steam flow to a second set of nozzles. The water suction and the water injection are separated into two separate steam nozzles. The water suction is then controlled by regulating the steam to the suction nozzles.
The overflow on these Metropolitan/Hancock is a pain, because the lever action closes the overflow whether the suction/injection ratio is correct or not, and sometimes causes it to fail to catch. That is why the disconnect for the action is provided. Also, the overflow ceases to provide a visual clue of operation.
PostPosted: Mon Jan 21, 2019 10:58 pm
Last edited by Kelly Anderson on Mon Sep 30, 2024 4:51 pm, edited 2 times in total.
PostPosted: Tue Jan 22, 2019 10:37 am
Also Williams Metals. They're closer to you so shipping might be cheaper.
https://www.wmwa.net/metal-products/copper/copper-pipe/
PostPosted: Sat Jan 20, 2024 10:49 am
I am looking for info on a metropolitan injector size 5n. this was apparently used on a barn hart log loader. my intent is to construct a reasonable faxcimily for a model. I can scale my drawing but only have this one view.
File comment: snip from actual drawings.
