It is currently Sun Oct 25, 2026 1:16 am
 Post subject: Caboose trucks campaign
PostPosted: Thu Nov 08, 2018 10:43 pm
We are doing well but need to try to meet our target, the first set of trucks is coming from Washington and trucking loading and unloading is going to be $3750. So please help, the trucks are being generously donated, and the Demolition of the caboose is done, with help from Facebook followers in the Renton area Drew Black in particular, we thank them so much.
The three or four trucks in Montana will be next but we don't know a price yet.
https://www.gofundme.com/6baoztc
Thanks a again to everyone
Mike Pannell
High Plains Railroad Preservation
 Post subject: Re: Caboose trucks campaign
PostPosted: Fri Nov 09, 2018 1:18 am
Is there another way to donate other than GoFundMe?
PostPosted: Fri Nov 09, 2018 3:20 pm
Hello yes,
Checks etc can be sent to High Plains Railroad Preservation, 1120 cactus hill rd, Cheyenne,WY 82001
Thanks
Mike Pannell
PostPosted: Fri Nov 09, 2018 6:35 pm
Thanks!
PostPosted: Sat Nov 10, 2018 3:20 am
I recently moved a pair of heavy Andrews trucks from Denver to Chicago using a truck broker that was 50% less than the other brokers I had called and they arranged for quick and convenient delivery with very short notice from me. I highly recommend them. If interested please PM me .Good luck on your project.
Mark.
PostPosted: Mon Nov 12, 2018 4:39 pm
Those trucks are glorious.
PostPosted: Mon Nov 12, 2018 7:30 pm
I didn't catch where the above frame and trucks came from, was this a UP caboose somewhere? The body was too far gone to be saved apparently.
PostPosted: Tue Nov 13, 2018 11:22 am
The caboose was in Renton WA, we aren't sure which CA1 it was but have saved the wood above the door which will tell us, its an OSL caboose we think anyway. Body was rotten as a pear under the cupola.
Mike Pannell
PostPosted: Tue Nov 13, 2018 7:09 pm
Mike Pannell
I noticed that you marked "save" on brake parts, the end railing and ladders, couplers etc, and it looks like the frame too, excuse my lack of knowledge but would you be able to essentially drop one of your caboose bodies down on this frame?
PostPosted: Tue Nov 13, 2018 8:03 pm
Not to speak for Mike, but, at least in theory, it would be possible to put another body right back on the frame. This would be especially true if the body and frame were of the same class and built by the same builder at the same time. Certainly one of Mike’s UP caboose bodies will be a perfect match for this frame.
Jason Midyette
PostPosted: Wed Nov 14, 2018 10:47 am
Sadly the frame will be cut , the costs of loading it and moving it preclude saving it, its approximately $7000 to $8000 to move it here without cranes each end as its a wide load. Also in order to put another body on the frame all the siding would have to be removed, it would be a nightmare job as they were never designed to come apart again. The CA1's are far more flimsy than the CA's despite having steel built into them.
Mike Pannell
PostPosted: Wed Nov 14, 2018 2:13 pm
Crazy Idea-Rotate the frame 90 degrees so it rests on one side-if it holds together. LARGE forklift could do the trick. Completely brace it. Now it would n0 longer be a wide-load and may not be a high-load either. Mind expanding drugs can be helpful.
