It is currently Sat Oct 24, 2026 11:33 am
 Post subject: Old air whistle - non-RR
PostPosted: Tue Jun 10, 2003 9:51 am
This list often sees discussion of air horns and whistles, so perhaps one of you can help. I have a building project for a new fire station where we have been asked to re-use the air whistle from the former building, circa 1920s. The data plate reads: FEDERAL AIR WHISTLE Model #1011 Serial #19811 60-120 PSIG.
I initially thought the manufacturer might be the present-day Federal Signal, but they no longer make such devices. A Google search has found no other leads, and local compressed air reps are unable to help. I would like to know the whistle's air flow requirement in CFM. Does anyone have an old catalog or other source?
Thanks!
tr2manz@frontiernet.net
 Post subject: Re: Old air whistle - non-RR
PostPosted: Tue Jun 10, 2003 10:30 am
I
> requirement in CFM.
Just a thought, but some dimensions might be more helpful than a part #.
Also, the term "air whistle" is just a bit vague. Does it have a standard whistle design or is it actually a horn?
PostPosted: Tue Jun 10, 2003 11:00 am
>...Does it have a standard whistle design or is it actually a horn?
It has three horizontal trumpet-style "horns", rotated 120 degrees from each other. It has a 1.5" air inlet, which also gives a clue to the required air flow.
I would like to find some old technical literature with exact specs, so I don't have to employ the SWAG method.
 Post subject: Horn & Whistle Group on YahooGroups
PostPosted: Tue Jun 10, 2003 10:40 pm
There's a Horn and Whistle YahooGroup I would sign up for and inquire there--the e-mail is Horn_Whistle@yahoogroups.com, but first register at groups.yahoo.com .
lner4472@bcpl.net
 Post subject: Yahoo Group
PostPosted: Wed Jun 11, 2003 3:21 pm
Thanks! I got my answer from those hornblowers.
 Post subject: Re: Yahoo Group
PostPosted: Wed Jun 11, 2003 4:57 pm
> hornblowers.
Now for the down side, you're in yahoo's database - I'll bet you'll have to change your email addys to get away from all the spam.
PostPosted: Wed Jun 11, 2003 5:20 pm
> hornblowers.
And those of us with nose problems are wishing to find out what you found out.
Any details you wish to share ?
lamontdc@adelphia.net
PostPosted: Thu Jun 12, 2003 9:20 am
> spam.
You can/could sign up with a free Yahoo mail ID instead; although if your e-mail address has been on the net as long as mine; your address is already on everybody's list anyway.
If you are only joining long enough to ask a question (as in this case), you can just stopping using it, and it will go away on it's own.
-James Hefner
Hebrews 10:20a
Surviving World Steam Project
james1@pernet.net
 Post subject: The answer is...
PostPosted: Thu Jun 12, 2003 12:22 pm
> wishing to find out what you found out...
Ah yes, Nostril-damus! Federal Signal does indeed still manufacture compressed air horns. Their tech rep is still searching for any archival information on my 75-year-old tooters. I will reveal all when they get back to me.
 Post subject: Re: The answer is...
PostPosted: Thu Jun 12, 2003 12:31 pm
> Nostril-damus!
Perfect fit and truer then you could ever imagine
Thanks
