It is currently Sat Oct 24, 2026 10:52 am
 Post subject: Water level indicator
PostPosted: Fri Jun 06, 2003 8:29 pm
Who has upgraded their tender to the new FRA regs adding water level indicators. Has anyone done anything different than just a plastic water column?
 Post subject: Re: Water level indicator
PostPosted: Fri Jun 06, 2003 8:39 pm
We used a pipe with holes drilled every 6 inches or so, I forgot the exact distance, it has been a while. Ours went right into the place where the original L&N one went.
david.wilkins@bardstown.com
PostPosted: Fri Jun 06, 2003 10:52 pm
We used sight-glasses and valves made by Ernst Flow Industries. They offer tons of different glasses and valves...also fusible plugs. The water tank sight-glass we went with has bronze valves and looks at home on the loco tank. The local FRA inspector was very happy with it. Our boiler backhead has two of their "reflex" style glasses rated for steam pressure. They have worked quite well.
Here is the web address....
www.ernstflow.com
Scott Wickert
Oregon Coast Explorer
steamlokie@harborside.com
PostPosted: Sat Jun 07, 2003 11:29 am
At The Valley, we installed four little brass petcocks at varying levels at the front of the cistern adjacent to the coal pocket: simple, effective and cheap.
J.David
jdconrad@snet.net
PostPosted: Mon Jun 09, 2003 2:31 am
> went.
Same for Frisco 1630 at IRM--easy and cheap!
Kevinmccabe@avenew.com
