It is currently Sun Oct 25, 2026 9:58 am
 Post subject: Bogie Lateral Control Springs
PostPosted: Wed Jun 06, 2018 3:57 am
We're a UK based organisation building a full size Class 6 "Clan" Pacific locomotive with the intention of mail line running. You can read about it here https://www.theclanproject.org/.
In order to meet railway certification rules, we need to keep as close to the original drawings as possible. We are very lucky as most drawings are available for copy at the National Railway Museum in York, UK. The front 2 axle bogie has rectangular section coil springs for lateral control which are proving very difficult to source. These have a 6 inch outer diameter and most similar die springs, available commercially, go up to a maximum outer diameter of around 2.5 inch.
We know that lateral control of the bogie is very important. E.S.Cox, the designer of the Clans, had had some very relevant experience in India in 1938 when investigating riding issues with the Indian XB Pacific. His autobiography tells us that this experience was adopted in his designs.
We have approached a number of spring suppliers in the United States, UK and Germany without success. We we wondering if anyone in your community had had experience of this type of spring and knew of a supplier?
Thanks
Ian
File comment: Spring specification on drawing
File comment: Rectangular section coil springs
 Post subject: Re: Bogie Lateral Control Springs
PostPosted: Wed Jun 06, 2018 11:28 am
Last edited by Kelly Anderson on Wed Nov 27, 2024 3:15 pm, edited 1 time in total.
PostPosted: Wed Jun 06, 2018 1:07 pm
Kelly
Thanks for the response. We have had a proposal from a UK supplier for nested round coil spring solution which were are looking at. The spring rate is not quite right and that is being looked at. We will probably have to convince the certification authorities if we go down this route; other locomotive groups have a similar problem.
I've attached an image of the solution with the springs fully compressed. We calculate that the end stops are reached before the spring is fully compressed. I understand that its not a good idea for the latter to happen
Ian
Springs commpressed at full Bogie Slide movement.pdf [957.89 KiB]
Downloaded 416 times
PostPosted: Wed Jun 06, 2018 1:50 pm
Last edited by Kelly Anderson on Wed Nov 27, 2024 3:14 pm, edited 1 time in total.
PostPosted: Wed Jun 06, 2018 2:28 pm
We've had a discussion on stacked Belleville washers already on a UK forum. The certification bodies have said no. I would be worried about grot and grime - inherent to steam loco operation - getting into the washers. One comment on the forum said
we had a set in an exposed place where grit got in to the pack. Crushed grit makes very effective grinding paste and our application was a high cycle one at the end of a reciprocating slide, washers ground away very quickly until somebody slit a coke tin and put that over the washers, sealing it up with gaffer tape.
I'm not sure we could get away with that on the UK main line!
Ian
