It is currently Sun Oct 25, 2026 11:50 am
 Post subject: EMD 372 contactors
PostPosted: Fri Apr 13, 2018 2:22 pm
Our SW9 has a contactor air cylinder that leaks bad enough at half travel to cause problems. Does anyone know if the piston can be pulled out the bottom after removing the cover, or does the whole unit need to be removed and disassembled?
Thanks
E
 Post subject: Re: EMD 372 contactors
PostPosted: Sun Apr 15, 2018 2:52 am
Not sure how much room you have below the power contactors, but the MI might help.
586 REV A POWER CONTACTOR PS7 372.pdf [1.26 MiB]
Downloaded 543 times
PostPosted: Mon Apr 16, 2018 11:56 am
Thank you. This helps immensely.
