It is currently Sat Oct 24, 2026 9:03 am
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
 Post subject: CDOT Budd SPV-2000 car auction
PostPosted: Tue Nov 07, 2017 9:36 pm
State of Connecticut is finally auctioning off the demotored budd SPV-2000 cars that have been sitting in New Haven yard for years.
Starting at one hundred a piece. Might take a bit of work to get them on the road again after all these years.
https://www.publicsurplus.com/sms/all,ct/list/current?orgid=187166
-DeAndre W.
(MTA) Metro North Railroad - MofE
Adirondack Volunteer Conductor/Engineer/Mechanical
SUNY Polytechnic Institute Alumni
 Post subject: Re: CDOT Budd SPV-2000 car auction
PostPosted: Tue Nov 07, 2017 11:10 pm
From the spec sheet, just in case anyone is actually looking for more "Thomas the Bank Engine" or Santa Train capacity:
CONSTITUTION LINER PUSH-PULL COACH (Shore Line East)
Converted SPV-2000 Rail Car
BUILDER: Budd Company
DATE BUILT: 1979 - 1980
OVERHAULED/CONVERTED: National Railroad Passenger Corporation,
SEATING CAPACITY: 102 - Cab Car 1993/ 1995
62 - Business/Cab Car
102 - Trailer Car
CAR BODY: Fluted Stainless Steel Body/Steel End Underframe
EVENT RECORDER: Pulse Electronics - Digital - Cab Cars
Model No. TTX-REC-02
CAB SIGNAL TYPE: Union Switch & signal Type EL - Cab Cars
BRAKE TYPE: 26 New York Air Brake/WABCO, SAB Tread Brake Units
AIR CONDITIONING: Stone Safety/York Rebuild 12 Ton Capacity
HEATING: Budd Company - Overhead 36 KW Floor 24 KW
BATTERY CHARGER: McGraw Edison - 74 Volt
COUPLER: AAR Type H
TRUCKS: Budd Company Pioneer III
BEARINGS: 6 inch X 11 inch Timken Co. Class F
DOOR CONTROL: Manual
WEIGHT: 102,000 lbs. - Cab Car 100,000 lbs.- Trailer Car
WHEEL DIAMETER: 33 inch - Type "B"
TOILET TYPE: Monogram Retention Type
Road Numbers: 1001 Business/Revenue Cab Car, 1 Unit
1671, 1673, 1675 Cab Cars, 3 Units
1621, 1623, 1625, 1627, 1629, 1631, 1633 Trailer Cars, 6 Units
Car Total: 11 Units
PostPosted: Wed Nov 08, 2017 11:26 am
I knew a man who made his fortune, post WW2, by purchasing surplus U.S. aircraft. He drained the fuel , sold it back to the air force, then broke up the thousands of planes for their aluminum. From refugee to millionaire, bingo.
At $100 a car, an entrepreneur might be able to do something similar. Just sayin'...
PostPosted: Wed Nov 08, 2017 5:42 pm
It's believed a previous "entrepreneur" in Delaware went belly-up trying to do exactly that with exactly these same cars in the 1980s.
Just a "word to the wise"..............
PostPosted: Wed Nov 08, 2017 7:18 pm
I don't know how much of a demand there will be for the SPV conversion cars.
I have been told, although nothings confirmed yet, that the six stored FL-9m's will be advertised next. They had been 'softly advertised' with little interest before. Current CDOT numbers of 2011, 2014, 2016, 2024, 2026 and 2027. Unservicable and haven't operated since 2009. I expect either a scrapper or outfit like LTEX will take them and if lucky one or two will survive in some form.
PostPosted: Wed Nov 08, 2017 7:36 pm
I believe that.
I was told they were offered in the past but the price tag was more than what they were worth.
-DeAndre W.
PostPosted: Thu Nov 09, 2017 4:28 pm
These cars are basically amfleet cars if I'm not mistaken are stainless steel. one of these cars be great for one of those budget scenic railroad's?
PostPosted: Thu Nov 09, 2017 4:45 pm
The only thing they have in common with an Amfleet is the fact that they’re made of stainless steel.
PostPosted: Fri Nov 10, 2017 11:12 am
What about couplers, interior fittings, seats, door locks, outside indicator lights, cables and sockets, etc.? These cars did run in trains with Amfleet cars.
PostPosted: Fri Nov 10, 2017 11:50 am
On the contrary: The SPV-2000s were built by Budd using adapted Amfleet shells and tooling, and the 13 ordered by CDOT were specified to be 100% compatible with Amfleet trains, including HEP and signal lines. Functionally, it's a standard Amfleet I series car with an engine, transmission, and cabs.
Honestly, though, the only places that have any justification for "saving" one of these as a relic is Danbury or Railroad Museum of New England. And we tend not to choose examples of "what NOT to do" for preservation.
And it would not look good for a car that still essentially looks like cars Amtrak still uses daily to show up at some rail excursion converted to an open car........
PostPosted: Fri Nov 10, 2017 1:28 pm
Alexander, I think you mean used to be, these have been neutered and converted into coaches, so they are actually Amfleet I cars with extra holes that used to contain the wiring for the Self-Propelled functions.
Structurally they might also be slightly different because of the loading due the drive train (beyond the additional mounting points).
Rich C.
PostPosted: Sat Nov 11, 2017 12:08 am
Yes but for thoes for profit operations this would seem ideal as they are stainless steel.
PostPosted: Wed Nov 15, 2017 6:00 pm
Connecticut Eastern Railroad Museum has an SPV-2000 in their collection:
http://www.cteastrrmuseum.org/spv.htm
They were an interesting footnote in history, but a mechanical and operational disaster from what I'm told by those who worked on them.
-otto-
—Otto M. Vondrak
Rochester, N.Y.
PostPosted: Wed Nov 15, 2017 7:10 pm
Eastern, and NYSWTHS have examples. Here's to hoping they don't become the next
GG-1, an example in most collections coast to coast. There are many mechanical differences between these cars and Amfleet's.
PostPosted: Wed Nov 15, 2017 8:05 pm
I've had it wryly suggested to me by someone who supposedly knows the flaws of the SPV-2000 better than I do that the best use for one of these lemons in preservation would be to blackmail the past operators for grants for their operations, or they would prominently restore the CDOT/Metro-North logos on the cars.......
But maybe an open shell for a private party car, dining car for a dinner train, or whatnot? We've seen more hare-brained schemes in the past, after all.....
