It is currently Sun Oct 25, 2026 9:11 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
 Post subject: Rock Island GP-7R 4506 at IRM
PostPosted: Sat Oct 28, 2017 6:49 pm
Progress:
 Post subject: Re: Rock Island 4506 at IRM
PostPosted: Sat Oct 28, 2017 8:59 pm
Glad to see that she's apparently safe, now.
 Post subject: Re: Rock Island GP-7R 4506 at IRM
PostPosted: Mon Oct 30, 2017 6:13 pm
Is it just me, or does that blue look lighter than bankruptcy blue?
PostPosted: Mon Oct 30, 2017 6:42 pm
It’s you.
PostPosted: Tue Oct 31, 2017 12:23 am
The photo was taken with inside-the-building lighting. Wait until it is out in the sunshine. Then we can make a judgement.
PostPosted: Tue Oct 31, 2017 12:25 pm
You have to really tip your hat to the fine folks at IRM. I have been a member for years, but have to really thank the volunteers that work tirelessly on these projects. The internal combustion department has been making one home run after another for the last several years. This is not unique, the passenger car department, freight cars, bus, trolley busses, steam shop, building & grounds, transit, all have had huge successes. In getting back to the internal combustion department, look at the list of restorations in the last decade or so.
Full to service and cosmetic restorations:
1) Joy Manufacturing #2
2) BN U-30-C #5383
3) CB&Q E-5A, #9911
4) CB&Q SW-7 #9255
5) CMSP&P H10-44 #760
6) CMSP&P HH-660 #1603
7) CB&Q SD-24 #504 (ex BX-6244, In movie Groundhog Day)
8) Illinois Terminal GP-7 1605
9) C&NW F-7A 411 (ex Metra 305)
10) C&NW Bi-level train set and cab car.
11) Wisconsin Southern E9-B 102 (ex Michigan Northern 671, UP 967B)
12) Rock Island GP-7 4506 (ex C&NW 4160)
In service, returned to service or in process of restoration
1) C&NW GP-7 1518 (The first GP-7 built, in shop for several years)
2) Southern Pacific SD-7 1518 (The first SD-7)
3) Wisconsin Central SD-45-2 7525
4) C&NW SD-40-2 6847
5) Green Bay & Western RSD-15 2407 (ex Santa Fe 841)
6) CMSP&P E9-A 33C (In shop for several years)
7) CMSP&P E9-A 37A
8) CMSP&P F-7A 118C
9) Santa Fe FP-45 92 (ex. ATSF 101 / ex 5992 / ex 5942 / ex 102)
10) CMSP&P U-25B 5056 (In shop for several years)
11) USA GE 45 tonner, 8537
12) Metra F7-A 305 (ex C&NW 414)
13) BN-1 F9-A
14) BN-2 F9-B
15) BN-3 E-9A
16) Commonwealth Edison 15 SW-1
17) L&N FA-2 314 (ex Long Island 604)
18) Nekoosa Paper 14 Alco S-3
19) Minneapolis Northfield & Southern DT6-6-2000 21 (Have not seen run recently, not sure if operable.
20) Union Pacific M-35 (1927 EMC in shop, progressing steadily)
21) Chicago & North Western RSD-5 1689
22) Union Pacific Dash 8-40-B 1848
23) Minnesota Transfer RS-3 200
24) BN E9-A 9908 (ex CB&Q 9976)
Real gems in the collection awaiting their turn,
1) Dardanelle & Russellville 14 EMC (1937 EMC with Winton engine)
2) TP&W RS-11 400 (not sure if operable.)
3) CMSP&P F-7B 96B (Could be used to make a Milwaukee Road A-B-A F-7 set)
4) CMSP&P FP-7A 104C (Could be used to make a Milwaukee Road A-B-A F-7 set)
5) Union Pacific DD40A 6930 Centennial (Has been used as a cab control unit at Diesel Days in recent years.
6) Union Pacific GE Turbine 18
7) C&NW RDC
8) Union Pacific H20-44 1366
9) ATSF Baldwin 543
10) Others.
Additions, corrections are always welcome!
No matter how you slice it, this is an impressive list!
PostPosted: Tue Oct 31, 2017 6:09 pm
2) BN U-30-C #5383
3) CB&Q E-5A, #9911
4) CB&Q SW-7 #9255
7) CB&Q SD-24 #504 (ex BN-6244, In movie Groundhog Day)
1) C&NW GP-7 1518 (The first GP-7 built, in shop for several years) (Ex EMD 100)
2) Southern Pacific SD-7 1518 (The first SD-7) (Ex EMD 990)
4) C&NW SD-40-2 6847 (Set to be painted within the coming years)
6) CMSP&P E9-A 33C (In the shop)
7) CMSP&P E9-A 37A (Placed in the shop)
8) CMSP&P F-7A 118C
10) CMSP&P U-25B 5056 (Removed from the shop several years ago)
13) BN-1 F9-A
14) BN-2 F9-B
15) BN-3 E-9A
17) L&N FA-2 314 (ex Long Island 604) (Re-wiring in process)
23) Minnesota Transfer RS-3 200 (Cab interior restoration has started)
24) BN E9-A 9908 (ex CB&Q 9976) (In the shop)
1) Dardanelle & Russellville 14 EMC (1937 EMC with Winton engine) (In the Shop)
2.5) TP&W Alco C424 800
6) Union Pacific GE Turbine 18 (The museum recently received enough money to cover half of the cost of storing this set indoors.)
7) C&NW RDC
8) Union Pacific H20-44 1366 (Ex Fairbanks Morse H20-44 2000 Demonstrator)
9) ATSF Baldwin 543
10) Columbus & Greenville Baldwin AS-416 606
11. Pullman Davenport 10-ton 1792
12. Ingersoll Rand ALCo-GE-IR 60-ton Boxcab 91 (Ex DL&W 3001 6th Boxcab built in 1926)
13. ARMCO Lima LS-1200 E100 (Last locomotive Lima ever made)
14. ARMCO Baldwin-Westinghouse Visibility Cab B-71 (Built in 1930 it is one of only two left to exist)
15. Other
I added a little bit more information on you're list. To be honest this is one of the best lists that I have seen for all of the Gas/Diesel locomotives that IRM has in its collection
PostPosted: Tue Oct 31, 2017 6:50 pm
2) BN U-30-C #5383
3) CB&Q E-5A, #9911
4) CB&Q SW-7 #9255
1) C&NW GP-7 1518 (The first GP-7 built, in shop for several years) (Ex EMD 100) nee EMD 922
5) Green Bay & Western RSD-15 2407 (ex Santa Fe 841) operable, but needs turbo work
8) CMSP&P F-7A 118C
9) Santa Fe FP-45 92 (ex. ATSF 101 / ex 5992 / ex 5942 / ex 102)currently at NRE, will be operable when it returns
11.5) GE 44 Tonner
13) BN-1 F9-A
14) BN-2 F9-B
15) BN-3 E-9A
17) L&N FA-2 314 (ex Long Island 604) (Re-wiring in process)Trucks and motors are "in the pipeline"
19) Minneapolis Northfield & Southern DT6-6-2000 21 (Have not seen run recently, not sure if operable. needs traction motor work
2) TP&W RS-11 400 (not sure if operable.)Needs rod bearings
should be operable when it arrives
3) CMSP&P F-7B 96B (Could be used to make a Milwaukee Road A-B-A F-7 set)former rotary snow plow power car X2, needs traction motors, rewiring in process
4) CMSP&P FP-7A 104C (Could be used to make a Milwaukee Road A-B-A F-7 set)main generator problems
7) C&NW RDC
8) Union Pacific H20-44 1366 (Ex Fairbanks Morse H20-44 2000 Demonstrator)needs oil cooler work, but GOD what a glorious sound when she ran...
9) ATSF FM H12-44TS 543
10) Columbus & Greenville Baldwin AS-416 606 Needs air compressor, and needs fuel tank to be reinstalled
13. ARMCO Lima LS-1200 E100 (Last locomotive Lima ever made)formerly operable, but needs oil cooler work, and whatever else has gone wrong in the last 30 years of sitting
15. Other
Further corrections in blue
Jeff
PostPosted: Tue Oct 31, 2017 8:12 pm
what ever happened to the UP Doodlebug? m-35?
PostPosted: Tue Oct 31, 2017 8:31 pm
What is the plan for Dardanelle & Russellville 14 EMC? It sure would be great to see a Winton run, It is totally do-able with the right people. It should be a special occasion kind of thing, but it can be done..
PostPosted: Tue Oct 31, 2017 10:14 pm
Makes sense to me. I always loved the CRI&P’s bankruptcy blue.
I’d like to ask a question about the Milwaukee Road E9A’s. What color will they be painted in once they’re both restored. UP Armour yellow?
PostPosted: Tue Oct 31, 2017 11:52 pm
Yes; both units were delivered in Armour yellow and remained in that livery until retirement.
Frank Hicks
Hicks Car Works
PostPosted: Wed Nov 01, 2017 9:54 am
Thanks for the updates to the IRM list! This is really an exciting list and time for this exceptional museum! Again I tip my hat to the fine folks who have worked and continue to work so hard to make magic happen again and again! I am so excited to see some of the projects move forward, and we all need to celebrate what has been accomplished!
PostPosted: Thu Nov 02, 2017 3:15 pm
What happened to the GTW RS1 #1951?
PostPosted: Thu Nov 02, 2017 11:09 pm
I forgot to add that one to the list. As far as I know, that last time I have seen it, it was in Barn 9. I don't think it is in operable condition.
