It is currently Mon Oct 26, 2026 10:20 am
 Post subject: Re: Turning Crankpins
PostPosted: Fri Aug 25, 2017 10:53 am
Sorry, hit the wrong key.
The use of the CLIMAX portable lathe would allow turning the crank pin surface without removing the drivers from the locomotive. It's esy to set up, does a great job and can leave a good finish - minumum hand polishing to complete the job.
But still; replacement of the rod brass.
Best Regards;
Gary P. Bensman,
Diversified Rail Services LLC
PostPosted: Fri Aug 25, 2017 11:05 am
I think you can grease them up, and cover them up, B&LE 643 has them covered up, don't leave them open in the weather. The grease may hold water away and from the air.
The issue may not be as bad as percieved, its a matter how far you want to go, you might not have pits but potential rough surfaces needing smoothing. Personally I like the idea of turning them giving them a clean bill of health.
PostPosted: Fri Aug 25, 2017 6:30 pm
Find a company that does in place machining for marine diesel engines. This industry has the capability and machinery to go inside these mammoth marine engines to turn crank journals in place.
