It is currently Sun Oct 25, 2026 9:13 am
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: U.S. Sugar / F.E.C. #148 restoration progress
PostPosted: Tue May 16, 2017 5:57 pm
"Does US Sugar have passenger cars lined up........"
Maybe borrow Brightline equipment! LOL
PostPosted: Wed Feb 07, 2018 2:15 pm
Some more pix from the Facebook page, Engine No. 148:
https://www.facebook.com/EngineNo148/
As usual, we have Facebook links and others for those who have difficulty with that source.
https://www.facebook.com/EngineNo148/ph ... =3&theater
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=5B1854C5
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=5B110ECD
https://www.facebook.com/steamoperation ... =3&theater
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=5B17CD17
Following safety valve photos by Jim Eng:
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=5B177A98
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=5B203DF6
Other photos:
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=5AE1F918
Lead truck parts awaiting evaluation:
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=5B163FC6
Lead truck work at Strasburg:
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=5AE3AEEF
Hub liners and crown brasses:
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=5ADC7D1F
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=5B1EC6F5
Bearing box "burn outs:"
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=5AE4F419
Cylinder boring, left side:
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=5ADA18D0
Cylinder liners.
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=5B1CC9EE
New leading truck wheel centers and tires.
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=5AD8069F
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=5B1BA469
PostPosted: Wed Feb 07, 2018 3:41 pm
Thanks for posting the update links. They are definitely "into it" now. What a "happy ending" for this locomotive. Often wondered what her fate was going to be. Bounced around an awful lot and didn't seem to be going very far towards being restored. Once again never say never {to myself}. Great to see. Regards, John.
PostPosted: Wed Feb 07, 2018 6:02 pm
Last edited by Kelly Anderson on Wed Nov 27, 2024 4:16 pm, edited 1 time in total.
PostPosted: Wed Feb 07, 2018 7:16 pm
New Wheel Sets or every thing cleaned up and new tires?
-Hudson
PostPosted: Wed Feb 07, 2018 9:02 pm
Those are roller bearings? So new axles too.
PostPosted: Thu Feb 08, 2018 8:59 am
PostPosted: Thu Feb 08, 2018 12:47 pm
Kelly was there a tremendous amount of engineering to convert that front truck to roller bearings? To me this sounds like a stupid question to ask, hope you don't mind. So what do the boxes that hold the bearings look like and how involved was this? Your almost finished product looks wonderful. Some people I know are involved in rebuilding a front truck on small 4-6-0 and I know we all would love to see how you went about the conversion. Or wishful thinking that it was not that hard to do and were able to use off the shelf parts. I would be shocked if that were the case. But there are some pretty sharp folks out there so I have to ask. Thanks for the update and picture. Think many of us are drooling about now. Regards, John.
PostPosted: Fri Feb 09, 2018 3:52 am
I second John Risley's question. We have considered converting to rollers on our two-wheel USATC Consolidation lead truck. Current journals are 6"x10" and wheels need to be replaced.
PostPosted: Fri Feb 09, 2018 9:37 am
Last edited by Kelly Anderson on Wed Nov 27, 2024 4:15 pm, edited 1 time in total.
PostPosted: Fri Feb 09, 2018 12:37 pm
Very interesting work and I thank you for taking the time to elaborate on this. For the project I mentioned I would agree it wouldn't be worth it. For something larger that might run on the main in excursion service I have no idea if it is a better move or again not? For our little ten wheeler I do not think the effort would be justifiable. But still a fascinating conversion to observe. Have read where other front and rear wheels {pony/pilot} on steam locomotives have been converted to roller bearings but most have been on larger excursion engines and have no involvement with them. Thank you again for your pictures and thoughts on the conversions. Regards, John.
PostPosted: Fri Feb 09, 2018 3:01 pm
Kelly Anderson wrote:
To replace the bearing, the wheel must be pressed off.
Mr. Anderson - Thanks for this nice presentation of a roller bearing conversion and your thoughts on some of the practical consequences converting from plain bearings to roller bearings. Can the need to press off the wheel to remove the bearing be avoided by the use of split roller bearings? They have more parts and so the install/replacement may be a bit trickier, but it could be done in the field where the equipment to press off the wheel is unavailable.
PostPosted: Fri Feb 09, 2018 3:23 pm
PostPosted: Fri Feb 09, 2018 3:40 pm
Mr. Anderson - I thought of this because your split box reminded me of what Timken calls, in the link you provided, the Support Cap and the Support Base (BSA calls it a Pedestal Cap and a Pedestal Base). Could the cap and base be machined as a split box that the cartridge top and bottom fit into? The cartridge top and bottom would keep the bearing together and clean when you drop the lower half of the box while the two halves of the box provide the mechanical support normally provided by the Cap and Base during use.
http://www.bsahome.org/tools/pdfs/Split_Roller_web.pdf
The more interesting issue would be the incorporation of a thrust bearing to control lateral motion of the shaft.
PostPosted: Fri Feb 09, 2018 4:00 pm
Scranton Yard wrote:
Mr. Anderson - I thought of this because your split box reminded me of what Timken calls, in the link you provided, the Support Cap and the Support Base (BSA calls it a Pedestal Cap and a Pedestal Base). Could the cap and base be machined as a split box?
All of this brings up at least part of why you didn't see too many conversions of steam locomotives to roller bearings in the old days.
A car journal, or any other outside bearing journal (such as a trailing truck), isn't too big a problem, as the bearing is on the outside of the wheel, and can be replaced without pressing the wheel off first. While some cars such as Amfleet apparently do quite well with inside bearings, that practice gets problematical with the higher axle loads and stresses in steam locomotives.
It's a different matter in the steam engines that were built with roller bearings from the start. Those engines had a nice, stiff, rigid cast frame that held excellent alignment, and where inside bearings were used, they were usually much larger tapered bearings in a "cannon box" housing that enclosed the axle and both sets of bearings, keeping alignment in that way as well.
They also typically had controlled lateral motion devices, again something plain bearing engines often lacked, especially as old as this one is.
I have a Facebook acquaintance who worked on a couple of 4-8-4s, one with plain bearings, and one delivered with rollers from the factory (which included tandem roller rods, by the way). He said those rollers, and the things that went with them such as those housings, practically eliminated the bearing troubles the company he worked for had on the other 4-8-4. He even said the rollers on the axles not only eliminated the bearing troubles, but all the work of dropping rods to work on bearings as well.
