It is currently Tue Oct 27, 2026 6:15 am
 Post subject: Boiler Plate Help
PostPosted: Tue Oct 18, 2016 5:35 pm
I suspect this will gather few replies, but I hope something comes of this inquiry.
I am currently tasked with the manufacture of a new boiler plate for a 1907 Henschel built locomotive. The plate is oval in shape, and has been long gone from the locomotive. The plate differs from Henschel plates 1910 and onwards, as those change to a round style and might also change the text and form of marking.
By any chance at all do members of this board have photos or an example in their collection that they would be willing to share photos of?
File comment: Locomotive the plate is for
Stuart Harrod
Steam shop machinist
Nordsjællands Veterantog
Veterantoget.dk
 Post subject: Re: Boiler Plate Help
PostPosted: Tue Oct 18, 2016 5:57 pm
Do you mean "builder's plate" rather than "boiler plate"? If so, a German-language board might be your best bet, even ebay.de, the SP9010 team has found artifacts on there. I couldn't find one from your era but found a newer one as an example:
http://www.ebay.de/itm/Henschelschild-L ... SwVL1V~Ac9
There are as many if not more railroad buffs in Germany as here, with a little luck (and more German language skills then I possess) you might find collectors. Good luck!
PostPosted: Tue Oct 18, 2016 6:07 pm
In this case, no. We have the original builders plates as visible in the photo below. The boiler plate has a construction number for the boiler, and should also mention the pressure the boiler can handle.
File comment: Thats me inside the tank
File comment: More modern version of what I am looking for
Stuart Harrod
Veterantoget.dk
PostPosted: Tue Oct 18, 2016 6:22 pm
Ah, German language skills would be helpful, I am sure a German steam fan would know the technical term for that item and could do a web search. "Boiler plate" is translated into "boilerplate" by some translation programs, which is a sort of defensive wording in legal documents.
PostPosted: Tue Oct 18, 2016 6:43 pm
"Boiler plate" in a noncolloquial meaning over here refers to the special grade of steel used to make the boiler itself. Your photo makes it clear that that isn't what you are needing...... I hope you find a good representative nearby. I know of a few small German narrow gauge industrial tank engines that found their way over here, not sure if I've ever noticed a manufacturers plate on the boiler of any of them like yours. You might try the two foot gauge owners association.
PostPosted: Tue Oct 18, 2016 6:58 pm
I was about to say the same thing, but you beat me to it!
-Philip Marshall
