It is currently Tue Oct 27, 2026 10:19 am
 Post subject: Re: Any EMD F units on AAR type B trucks?
PostPosted: Fri Aug 19, 2016 2:33 pm
To further confuse the issue, the truck EMD used on their switchers and later recommended by the AAR for use by all locomotive manufacturers, was also designed by Martin Blomberg in 1937: https://www.google.com/patents/US2137074
I guess that makes it a "Blomberg truck", too.
Someplace in reading about the GSC swing-motion truck, I ran into someone asking who designed it, apparently looking for a name to attach to it. I find it odd no one recognizes it for what it is; the suspension, drop equalizers and a floating bolster supported by swing hangers, is identical to the truck the Master Car Builders Association was recommending for passenger cars since at least the 1890s. Indeed, when they began to be adapted as motor trucks for interurban cars in the 1910s, they were often described as "MCB trucks." Commonwealth Steel Co. adapted the suspension design to cast sideframes during the twenties, and the trucks just grew in capacity from there.
PostPosted: Fri Aug 19, 2016 3:38 pm
Not meaning to be a smartass, Dennis, but I knew that. The subject was covered in an ancient copy of 'Railway Mechanical Engineer.'
Dave
PostPosted: Fri Aug 19, 2016 5:12 pm
I assumed so, but perhaps there are others reading who didn't.
PostPosted: Fri Aug 19, 2016 5:15 pm
Good point.
Dave
PostPosted: Sun Aug 21, 2016 11:16 pm
NH0401 wrote:
No such thing as an 'AAR Type B' truck. Erroneous railfan nomenclature. The correct designation is GSC swing bolster, double equalized truck.
Alco called them 'AAR Type A' and 'AAR Type B' trucks in their literature over 50 years ago... I'll take their word for it, even if the AAR never designated them as such.
CD
PostPosted: Mon Aug 22, 2016 6:00 pm
Yes!!! On the Alaska RR...
ARR 1505 circa 1982.
ARR 1505 circa 1984.
jerry
Passenger Car Photo Index Updated 8/9/17 with 8,402 new links
Interurban Car Photo Index
PCC Car Photo Index
PostPosted: Mon Aug 22, 2016 9:57 pm
Jerry, Thanks for the interesting pics of AAR 1505. I wonder if any F7 A units had them trucks fitted while on the AAR?
Robert
PostPosted: Mon Aug 22, 2016 10:14 pm
Its worth noting that 1505 had the B-trucks since at least 1971...
http://www.alaskarails.org/pix/former-loco/UK-1505.html
In looking through the Alaska Rails site I only found shots of 1505 so it is hard to say if anything else received them. Their GP7Ls also road on B-trucks.
jerry
PCC Car Photo Index
PostPosted: Mon Aug 22, 2016 11:16 pm
Termite7 wrote:
Here is a TVRM locomotive...I think it was a former Army unit...I may be wrong.
My understanding is that it was a cost-savings measure when they traded in old ALCOs they used the old trucks. It may not make any sense with today's economics but it sure did back in the day.
http://www.pbase.com/image/133776505
T7
At least one other railroad had GP7s riding on switcher trucks. This was the Nashville, Chattanoga, & St. Louis.
http://donsdepot.donrossgroup.net/dr0107/ncstl703.jpg
http://www.ncps-576.org/equipment/diesel/703.htm
