It is currently Tue Oct 27, 2026 9:07 pm
 Post subject: Box Under Cab on DT&I engine
PostPosted: Wed Mar 09, 2016 6:48 pm
File comment: Box Under Cab
Hi all
I found this shot on the Web , I was wondering if anyone has any idea what this box is under the cab of DT&I Locomotive , Thanks Pat
 Post subject: Re: Box Under Cab on DT&I engine
PostPosted: Thu Mar 10, 2016 7:08 am
my best guess is there isnt much room on the tender for extra storage so they made a compartment there. Otherwise it may be the location for a stoker engine.
PostPosted: Thu Mar 10, 2016 11:45 am
DT&I was owned by Ford, right? It's the toolbox to carry the screw jack, monkey wrench, and combination slip-joint pliers / screwdriver that came with every Ford vehicle.
Sorry, I couldn't resist.
PostPosted: Thu Mar 10, 2016 2:34 pm
Actually Dennis, you aren't that far off with that guess! DT&I locomotives during the Ford era were equipped with a comprehensive tool box that even included a drop light to inspect the running gear.
PostPosted: Thu Mar 10, 2016 3:24 pm
Tool storage or a box containing a signal system for the locomotive....? Seems a bit odd of a place for a tool box, as it blocks the injector and makes maintenance more difficult...
Stuart Harrod
Steam shop machinist
Nordsjællands Veterantog
Veterantoget.dk
PostPosted: Thu Mar 10, 2016 3:37 pm
It's not blocking anything - engine has a lifting injector, located in the cab. What you see underneath is just the water hose connection to the tender. It's most likely a tool box that's much roomier than a seatbox. Would be easier to tell if the pic wasn't so small.
PostPosted: Thu Mar 10, 2016 4:00 pm
There are plenty of pictures of locomotives equipped with tool boxes on this website:
DT&I Steam Locomotive pictures
For some reason, the DT&I cab seats during that era were just seats with sturdy legs- no seatbox.
