It is currently Wed Oct 28, 2026 3:48 am
 Post subject: Need help with headlight bezel pattern
PostPosted: Fri Jan 15, 2016 3:25 pm
I am making a headlight bezel foundry pattern for a 14" Sunbeam locomotive headlight. I am working from a fragment which only has one screw which holds the lens ring in place. I would like to know the correct number of screws used to hold this ring in place. I know the 16" headlight has eight. Any help would be appreciated.
Bernie Perch
 Post subject: Re: Need help with headlight bezel pattern
PostPosted: Mon Jan 18, 2016 1:40 pm
Bernie,
I believe that the style you are looking for has 8 screws to hold the glass in the bezel.
Attached is a photo.
Hope this helps,
JD Johnson, Morehead North Fork Railroad Historian
PostPosted: Mon Jan 18, 2016 2:16 pm
JD,
The photo you are showing is the 16" diameter version that I mentioned above. I am probably going to go with six screws for the 14" version. I believe that the 14" version is a rare item.
Bernie
