It is currently Wed Oct 28, 2026 7:47 am
 Post subject: KarTrak ACI tags
PostPosted: Thu Jan 14, 2016 11:49 am
Does anyone have experience replicating KarTrak ACI tags for their equipment restoration? These are the optical car tags used in the early 1970s.
 Post subject: Re: KarTrak ACI tags
PostPosted: Thu Jan 14, 2016 1:09 pm
find a good picture have a decal made and apply it to a piece of sheet metal. Pop rivet or screw the sheet metal to the car. Any good sign shop that does vinyl graphics should be able to replicate one for you.
PostPosted: Thu Jan 14, 2016 1:26 pm
Does anyone have the translation document for this system, aka this image equals the letter A, and this image equals #2, ...?
Was the `bar-code' reflective or regular paint? The ones that I have seen are too oxidized to tell.
Rich C.
PostPosted: Thu Jan 14, 2016 1:44 pm
Here is the Automatic Car Identification (A.C.I.) System explained.
http://www.nakina.net/other/aci/aci.html
http://www.icrr.net/aci.htm
/Andrew
PostPosted: Thu Jan 14, 2016 5:57 pm
Then if you could have the guy who drew "Herbie" put one on your car it would be a sight for my sore 1970s eyes.
PostPosted: Fri Jan 15, 2016 2:39 pm
Does anyone have the car owner 4 digit code list? The first webpage references one at the bottom, the link is bad, either the file was moved or deleted.
Thanks,
Rich C.
PostPosted: Fri Jan 15, 2016 3:46 pm
Any edition of the Official Railway Equipment Register from the UMLER era (Universal Machine Language Equipment Register) should have the list. I have one from May 1983. What railroad do you need?
PostPosted: Fri Jan 15, 2016 4:07 pm
Here is Eric Neubauer's explanation of the Automatic Car Identification (A.C.I.) System with the four digit owners identification codes provided at the bottom. This is the PDF that was referenced at the bottom of my first link.
http://eaneubauer.ipower.com/aci.pdf
/Andrew
PostPosted: Tue Jan 19, 2016 2:08 am
We managed to sort-of replicate some optical tags for a repainted pair of "L" cars last year. The tags in question are not the ACI KarTrak type; instead, they're tags from a similar (but not identical) bar code system which was produced by Wabco. I'm not an expert on ACI tags, etc., but as I understand it, this Wabco bar code system was one of four which the AAR tested prior to selecting a system of automated car identification. Although KartTrak was chosen there, the Wabco system was used on (at least) the CTA.
For the tags on our "L" cars, we were fortunate enough to have been donated (by the CTA) a stack of surplus adhesive Wabco tags which were printed printed for a multitude of cars in the same series but never used. One of our volunteers did the necessary homework, and deciphered the bar code. Then from the stack of surplus tags we had, he was able to cut (very carefully) the correct bars for each numeral corresponding to the numbers on our cars and affixed them to a "base" tag. The end result is an accurate bar code which looks pretty good. (see photos below)
The tags themselves seem to be made from reflective Scotchlite, and I've been told by the volunteer who did the legwork on these Wabco tags that proper ACI KarTrak tags are comprised of the same material. An X-acto knife, straight edge, and a supply of Scotchlite in the right colors is probably all you need to make new ones.
The tag is on the first side door from the front of the car(s), in the green area below the windows.
Closer shot of one of the tags, taken the other day (in so-so lighting) in the barn.
Up-close, you can see how this tag was put together using the individual numeral bar codes from the supply of complete tags we had on hand.
Wabco logo
