It is currently Wed Oct 28, 2026 8:42 am
 Post subject: Re: 600 V. DC Electric rectifier/substation
PostPosted: Wed Dec 09, 2015 10:01 pm
Pegasuspinto wrote:
RCD wrote:
softwerkslex wrote:
How does 480 become 600 in the final output?
Transformer
Please read above. If you try to rectify 600 VAC to 600 VDC all you will get is a very expensive mistake.
The output of the transformer would be >600VAC to allow for voltage drop across the full wave bridge rectifer then a coil to smooth out the ripple. I have seen a set up like this before although it was not running 600v
PostPosted: Thu Dec 10, 2015 5:14 pm
Here you go, likely from the Cleveland Rapid:
http://www.ebay.com/itm/2000-kw-Silicon ... xyYTRSWDZN
PostPosted: Thu Dec 10, 2015 5:48 pm
Did they take the pictures with a potato? For 11k you think you could get a readable shot of the data tag.
Only $51.48 shipping!
Before you buy, make sure you can get 11,000 volt 2000kva primary service from your utility!
PostPosted: Thu Dec 10, 2015 6:28 pm
The substation shown on Ebay would seem to be a bit oversize for running a small museum operation!
PostPosted: Thu Dec 10, 2015 6:59 pm
Also should point out I think you could get really, really close to six digits on the rest of the substation. The main primary circuit breaker would probably be at least 30-50k alone and that's without the panels to mount it in.
PostPosted: Sat Dec 19, 2015 6:00 pm
I'm always skeptical of numbers which seem unachievable. I find they are usually either naysaying, pie-in-the-sky, or a professional accustomed to bidding government jobs with all their cost-adders. Nobody in railway preservation can afford that kind of gold plating.
Maybe it's my Detroit/California bias where many industries are coming out never to return, but there's a glut of the type of AC switching equipment you need. We got a set "free" with purchase of an old pallet factory.
One important feature you may need to spend real money on, is the arc fault or "rate of rise" detection. It looks for current changes (generally upward) that cannot be explained by a compressor startup or taking of points. Because it is measuring millivolts across an ammeter shunt, the device doesn't know or care the capacity of your substation, so that doesn't bear on the cost of it. I'd pencil in $5000 for one of those, with hopes of finding a less expensive way to do it.
2000kva is the rating of the substation. Just like you can put VR-rated tires on a car that can't make 130mph... if the power company can't provision 2000kva, just set your breaker for what they can provide. You want yours to trip before theirs.
To get even closer to flatline DC, I've seen arrangements using two sets of transformers (or two sets of taps) 180 degrees out of phase with each other, a sort of "6-phase" power if you will.
