It is currently Sun Oct 25, 2026 12:33 pm
What is the staybolt stress for the FRA Form 4?
Poll ended at Wed Sep 09, 2015 5:13 am
A) 3342 0%  0%  [ 0 ]
B) 4041 0%  0%  [ 0 ]
C) 3993 0%  0%  [ 0 ]
D) 5359 50%  50%  [ 1 ]
E) 5014 50%  50%  [ 1 ]
F) 2463 0%  0%  [ 0 ]
G) 2092 0%  0%  [ 0 ]
H) 2424 0%  0%  [ 0 ]
Total votes : 2
 Post subject: Re: What is the staybolt stress?
PostPosted: Fri Aug 28, 2015 10:24 am
M Austin wrote:
Dave wrote:
might need to apply a little trigonometry to work the angles
Actually, no. The wonders of the Belpaire firebox is the crownstays are radial and perpendicular to the roof and crown sheets. No fancy calcs required.
It is still a science, sliderules you know, the belpaire would not have been designed if concepts were not worked out.
PostPosted: Sun Aug 30, 2015 11:28 pm
Hi All
For your reading pleasure from 49 CFR part 230.
§ 230.25 Maximum allowable stress on stays and braces.
The maximum allowable stress per square inch of net cross sectional area on fire box and combustion chamber stays shall be 7,500 psi. The maximum allowable stress per square inch of net cross sectional area on round, rectangular, or gusset braces shall be 9,000 psi.
§ 230.26 Tensile strength of shell plates.
When the tensile strength of steel or wrought-iron shell plates is not known, it shall be taken at 50,000 psi for steel and 45,000 psi for wrought iron.
The above material was taken from the following site.
http://cfr.regstoday.com/49cfr230.aspx#49_CFR_230p24
Robby
PostPosted: Sun Aug 30, 2015 11:31 pm
I agree with CCDW
Robby
PostPosted: Tue Sep 01, 2015 5:44 am
Ye gods, I never saw so much palaver about something reasonably straightforward. The question doesn't call for strains, or properties of materials, or include the factor of safety, or involve any weird math. And if there is a technical glitch in the 'poll' function -- just provide the fricken answer in a short post, and let the interested tot up the results themselves.
The actual Form 4 is not difficult to find. Go to
https://safetydata.fra.dot.gov/Officeof ... forms.aspx
and scroll down to 'Steam Locomotive form 4' This can be viewed or downloaded as a PDF file.
The relevant item under "Calculations" calls for the maximum STRESS on the crown stay under maximum load. In the example, which is happily 'orthogonal' thanks to the Belpaire geometry, you have all the math done for you; it would appear all you have to do is think. Threaded diameters and such are red herrings (except God help you if they are actually lower than that for the thinnest designed section of the staybolt in question!): the only two things of concern are the items in the data table for the stress imposed by the roof against the smallest diameter of the stay, and the stress imposed by the crown against the smallest diameter of the stay.
The Form 4 calls for maximum stress, so the greater area acting on the roof end of a given stay predominates. That is given as 5359.
Now, I would think the load, and hence the maximum stress actually imposed on the stay (assuming no nominal stress at neutral temperature and pressure) would be the *sum* (resultant with forces 180 degrees apart) of the forces exerted by the relevant 'patches' of roof and crown, divided by the minimum cross-sectional area of the staybolt. I do not see this reflected in the calculations given for the poll. No, I have never filled out an actual Form 4 so I don't know if this is a trick 'none of the above'. I look forward to inding out why this assumption is wrong.
PostPosted: Wed Sep 02, 2015 2:12 am
The correct stress value is E) 5014 psi.
Hint:
PostPosted: Wed Sep 02, 2015 7:25 pm
Shows why you don't do math with a 101-degree fever. And mistake the force on the staybolt for the stress.
Of course the resultants balance on the staybolt in question - the stress in tension at one 'end' will equal the stress anywhere else in the 1" section.
PostPosted: Sat Sep 05, 2015 5:25 am
Unless the boiler is exploding, the load on each end of the staybolt must be the same. All things being equal, (even sheet thickness) the extra load applied to the roof sheet due to the greater staybolt pitch will exhibit itself in greater "quilting" deflection than on the crown sheet. The greatest stress in a staybolt will always be the load of the smallest pitch area divided by the smallest cross sectional area of the staybolt.
PostPosted: Fri Sep 11, 2015 5:30 pm
Stress cracks in large radius corners.
