It is currently Wed Oct 28, 2026 8:10 pm
 Post subject: The Latest from the Strasburg Rail Road Shops
PostPosted: Fri Jun 26, 2015 4:54 pm
Last edited by Kelly Anderson on Fri Nov 29, 2024 4:54 pm, edited 3 times in total.
PostPosted: Fri Jun 26, 2015 7:42 pm
Thanks Kelly! I look forward to seeing your updates and am impressed by the talent up there.
PostPosted: Fri Jun 26, 2015 9:32 pm
I love these "can do" updates, Kelly. Thank you!
PostPosted: Sat Jun 27, 2015 10:57 am
Kelly... Curious to what you used to check the diameter of # 90's tires when they were being turned on the wheel lathe? It's amazing to me that you were able to get all sets within .005 of each other. You have a very talented shop down there....
PostPosted: Sat Jun 27, 2015 8:10 pm
So a "slow leak of oily lead" is lead that didn't solidify? Or was the cavity partially full and with the shifting it carved away pieces of lead each time?
PostPosted: Sun Jun 28, 2015 9:14 am
Last edited by Kelly Anderson on Fri Nov 29, 2024 4:53 pm, edited 1 time in total.
PostPosted: Sun Jun 28, 2015 11:40 am
Kelly,
I don't know if you picked out a name for the above mentioned passenger car, but when it was at the WK&S, some people referred to it as the "Somerset" as that was were it was located before the railroad got it. So if you are looking for a name, I nominate " SOMERSET".
Bernie
PostPosted: Sun Jun 28, 2015 1:20 pm
The superheater unit bolts have a center on the T end. Is that just a center for turning and threading or does the round stock thread into the T section? As usual Strasburg updates are the high point in reading these RR posts.
PostPosted: Sun Jun 28, 2015 4:45 pm
simply outstanding work
PostPosted: Sun Jun 28, 2015 5:06 pm
Last edited by Kelly Anderson on Fri Nov 29, 2024 4:52 pm, edited 1 time in total.
PostPosted: Mon Jul 06, 2015 10:35 pm
So... when does work start on the PRR T1 5550 Duplex? ; )
Thanks for the report, details and photos - all very much appreciated and thoroughly enjoyed!
/Mitch
PostPosted: Tue Jul 07, 2015 9:33 am
As soon as the principals show up with a couple suitcases full of cash.
And that's just for the estimates. ;)
PostPosted: Tue Jul 07, 2015 10:21 am
Somerset would be a good Pennsylvania-connected name for the B&O car.
If it was built for the B&O, rather than an acquired line, then another possible name would be Daniel Willard, President of the B&O in 1911.
Tom
PostPosted: Tue Jul 07, 2015 11:30 am
Great update Kelly! Thanks for keeping us in the loop.
