It is currently Wed Oct 28, 2026 8:30 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 123 posts ]  Go to page 1, 2, 3, 4, 5 ... 9  Next
 Post subject: Trash in Firebox
PostPosted: Sun Jun 14, 2015 8:46 am
Occasionally I will see guys throw glass bottles, aluminum cans, into the firebox. Aside from the waste of a recyclable resource, is this bad for the engine? Is that molten glass going to jam something in the grates or ashpan?
 Post subject: Re: Trash in Firebox
PostPosted: Sun Jun 14, 2015 9:34 am
Small occasional doses will just turn into traces in the cinders. If a considerable part of the constant fuel diet, troublesome.... but apart from those of us that burn waste crankcase oil, which is a form of recycling in itself, I don't think anybody is feeding enough trash as a fuel stock to make much of a difference. It would be nice to develop good workable fuel stocks from waste products, better than landfills.
PostPosted: Sun Jun 14, 2015 9:54 am
I am a bit concerned about the glass bottle serving as a flux for cinders or actively adhering to movable parts and then 'freezing' when the temperature drops. There might be an increased tendency to form dead spots in the firebed, for one thing. I don't know offhand if fluxed ash constituents or glass would lead to overheating or 'corrosion' of the grates, or whether deposits on the ashpan would adhere and be difficult to clean, but I'd at least keep watch for that.
There might be a problem with carryover of some trash or pyrolysis products into the flues or smokebox. I doubt the occasional aluminum can would pose much difficulty -- I'd be more concerned, again, that the melted metal would adhere to the ashpan and be difficult to remove.
A potential concern is if the ash is being sold for some recycled purpose. Certain types of 'contaminant' might make it unsuited for whatever purpose it's being used for, and the 'recycler' might not be aware, or test for, some contaminants because they think it's unlikely they'd be present in a locomotive fire (as they might be in, say, ash from a commercial incinerator).
PostPosted: Sun Jun 14, 2015 10:21 am
The fire burning can melt metal/glass but the firebox etc system stops all that because of the water causing cooling. Why we don't have more boiler explosions. I'd be concerned of flue buildup any potential metal corriosion enhancing chemicals, but little bits may not do much. If you threw your trash bin in I'd say...hay, weight a minuto...
PostPosted: Sun Jun 14, 2015 11:13 am
An aluminum can would pretty much vanish in a hot fire. I kind of expect that glass would end up in blobs in the ash.
PostPosted: Sun Jun 14, 2015 11:26 am
Clinkers are essentially glass, so the bottle thrown in would make its own little clinker, and that would be that. You wouldn't want to throw in fifty glass bottles evenly distributed throughout the firebox, but I don't see one causing a noticeable problem.
PostPosted: Sun Jun 14, 2015 12:12 pm
You do have to watch out for empty Wendys Chilli bowels.
I saw a bag of these tossed into a firebox and the Pops lifted! ;-)
-Hudson
PostPosted: Sun Jun 14, 2015 2:23 pm
-Hudson
I'd hate to see anyone's "bowels" tossed into a firebox!! ;)
Big Jim Video Productions
Morrisville, PA
PostPosted: Sun Jun 14, 2015 4:23 pm
I don't think they would smell like BBQ....
PostPosted: Sun Jun 14, 2015 4:51 pm
I've seen the occasional pop can put in through the sanding hole, almost like loading a torpedo.
I've also seen the occasional can at a campfire, and they are so thin they quickly burn into a very thin ash. You'd ned to toss a lot of them for it to be a real problem.
PostPosted: Sun Jun 14, 2015 6:48 pm
I was once diagnosed with Wendy's Chilli Bowels.
PostPosted: Sun Jun 14, 2015 7:09 pm
That's what might be called a "habanero hotbox"!
PostPosted: Sun Jun 14, 2015 11:24 pm
Dave wrote:
.... but apart from those of us that burn waste crankcase oil, which is a form of recycling in itself....
no, it's a form of pollution. Used motor oil contains heavy toxic metals and other nasties picked up from the innards of the engine. You shouldn't even use it to lube switch points because it will turn the dirt under the switch into "dirty dirt" that will require disposal in a special landfill if tou are caught. That is why lube oil should be properly recycled. OR....
google "black diesel" and note the purification processes they use - notably with centrifuges to get rid of the nasty heavies. The light fraction coming out of the centrifuge should be ok.
Aluminum cans burn because like many metals (sodium, uranium), aluminum is pyrophoric. It wants to oxidize a lot, and will do so violently and exothermically in the right conditions.
PostPosted: Sun Jun 14, 2015 11:31 pm
Robert, no matter what you recycle it will in some manner result in something which can be described as pollution. Breathing, for example.....
PostPosted: Mon Jun 15, 2015 1:25 am
Well if you're exhaling lead, chromium or arsenides, you really might want to see a doctor!
