It is currently Wed Oct 28, 2026 12:25 am
 Post subject: Waukesha propane tanks
PostPosted: Fri Apr 10, 2015 5:38 pm
Niles Canyon Railway has at least 20 more Waukesha propane tanks than we will ever need. Tanks are ~120 lbs tare, hold 100 lbs LPG, and are designed to be filled and used in a tilted-20-degrees-from-horizontal position (i.e. the standard Waukesha propane tank box under a railroad passenger car). The surplus Waukesha tanks do NOT have the modern valves with a bleeder port.
If you want any of these surplus tanks, please send me a PM. Otherwise they're headed for the scrap bin in a month or two.
Thanks! - Doug Debs
