It is currently Thu Nov 26, 2026 2:09 am
Post new topic Reply to topic  [ 124 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
 Post subject: Re: Slide Scanner Recommendations
PostPosted: Tue Jan 13, 2015 4:43 pm
Thank you Don Strack for suggesting FastStone Photo Resizer!
http://www.faststone.org/FSResizerDetail.htm
Just did a batch of about 400 slides and FastStone Photo Resizer was a big help with the post-scan processing, labeling & resizing.
It didn't automate everything, but it cut down what I had to do manually by a significant amount of time.
-Hudson
PostPosted: Wed Jan 14, 2015 1:01 am
Many thanks to the experts here on the science then art of photo/slide/film scanning to digital rendering. From what I'm reading here and other places scanning and rendering color digitals from negatives is a whole "nother" level. The Family collection of circus and train "Photos" is a mixture of prints/negatives and slides color and B/W. Also have all the 120 format negatives from my wedding (the photographer retired and sent them to us). I suspect that my getting into this will be a process of ever advancing skill, understanding, and investment. For now I'm just tinkering with prints.
Cleanliness is next to godliness. I noticed scanning the print below that the lab that did the print in 1996 had some issues with dust bunnies. After scanning the photo I was taken back by white "fibers" in the digital rendering. Upon close inspection I could see them in the photo. Little fibers that made it in when the print was made in the lab. (being black on the negative they translated to white on the print)
Here is one of the little fibers I took out of the pic
I scanned the image using the flatbed of my HP LaserJet M1212nf MFP (not exactly your first choice for quality renderings but for the occasional print not bad)
Set it to scan at 1200 dpi as a tiff, then used FastStone to fine tune it, clean it up and down size it for posting. (got tired of tinkering and left the "one shot" camera date in)
I second the thank you to Don Strack for the FastStone tip!
PostPosted: Thu Feb 19, 2015 1:30 am
Additional Information:
I have found the month taken and location info for the following slide (see end of post).
Rainier Rails wrote:
GN FA1 #276B (probably with #276A), which according to the GNRHS-NPRHA Archives, was assigned to the Kettle Falls branch, so this photo was likely taken in Spokane. The slide was a duplicate made by R.R. Wallin; I don't know if he was the photographer or a later owner of the original.
Does anybody have the order, frame, and serial numbers, as well as the build dates for the #276A-#276B? Thanks in advance!
http://www.rrpicturearchives.net/showPicture.aspx?id=4057355
I noticed another listing on Ebay of the same slide, with the seller including the following info:
jwright61 wrote:
Offered for bid is a duplicate 35mm color slide from the Blackhawk Films 'Those Famous Alco Diesels---PA's FA's and DL-108's---Western and Canadian Roads' collection. The caption states: 'Great Northern FA-1 No. 276B/A at Vancouver, Washington. June 1965'.
Ted Brumberg
PostPosted: Thu Feb 19, 2015 7:01 am
Regarding where this slide was taken, "K Burd" posted the following comment on RR Picture Archives:
K Burd wrote:
This is Vancouver, BC, Canada - not Vancouver WA - you can tell by the large "W" sign in the background which was a landmark on top of the Woodwards Department store.
Ted Brumberg
PostPosted: Sat Aug 22, 2015 6:49 am
Here's another slide I've scanned:
UP E8A #937 leads an A-B-B-B-A lashup, the power for the eastbound City of St. Louis ascending Cajon Pass in 1964. Depending on the exact date, this might actually be the combined City of Los Angeles-City of St. Louis. This slide was taken by F.H. Wolsford, and the duplicate that was for sale on eBay was marked as Blackhawk Films. (Apparently the slide of GN FA1's #276A and #276B which I featured earlier in this thread also had duplicates sold by Blackhawk.)
http://www.rrpicturearchives.net/showPicture.aspx?id=4258670
Ted Brumberg
PostPosted: Sun Aug 30, 2015 5:01 am
2 more scanned slides. These are both original Kodachromes, taken by an unknown photographer in April 1970 of 2 SP chairs in Tempe, AZ. The cars are being used as a shuttle service out to Davis-Monthan Air Force Base, providing transport for those taking the tour of the stored/retired aircraft at the Aerospace Maintenance & Regeneration Center. The signs attached to the sides of the cars give instruction as to where to board and advertise the train, respectively; unfortunately, these signs are placed over the car numbers.
http://www.rrpicturearchives.net/showPicture.aspx?id=4258617
http://www.rrpicturearchives.net/showPicture.aspx?id=4258618
Ted Brumberg
PostPosted: Sun Sep 06, 2015 5:38 am
Another slide:
CN (Newfoundland Railway/Terra Transport) narrow gauge lightweight baggage car #1301, built as NFLD #221. This is an original Kodachrome slide taken by John C. Benson in St. John's on July 13th, 1981.
http://www.rrpicturearchives.net/showPicture.aspx?id=4258604
Ted Brumberg
PostPosted: Mon Sep 07, 2015 7:03 am
I recently acquired 7 Dick Wallin duplicate slides from John Benson of GN engines and passenger trains, and here's one of southbound train #460 leaving Tacoma Union Station in April 1965, led by F7A #364C and rebuilt F7B #350B. On this day, #460 has at least 9 cars, the last of which is a NP lightweight. The GN storage mail appears to be from the #239-#241 series, and I belive it is #239. The first 3 coaches/chairs are from the #950-#979 series built by B&S in 1914 as #4500-#4529. The first is one of several from this series which were streamlined and switched from a coach to a chair configuration, the next 2 are of the modified variety with A/C installed in the mid-1930's, no way to tell without knowing the car number if these are coaches or chairs. The #364C was built in October 1950 and was later BN #9728. BN sold the engine to Precision National in November 1974. The #350B was built in November 1947, originally as a F3B, and was rebuilt after a wreck as a F7B with the same number, outshopped on June 22nd, 1952. F3A #350A was also rebuilt to a F7A after that wreck. The #350B was later BN #9701, and was sold in March 1974 to Simon & Sons. I don't know who the photographer was, and this is a duplicate Kodachrome slide, which is stamped June 1978.
Just a note: I have previously posted 2 slides which I also acquired from John Benson: UP E8A #937 at Cajon, CA, and Santa Fe motorcar #M190 in Clovis, NM.
http://www.rrpicturearchives.net/showPicture.aspx?id=4287014
Ted Brumberg
PostPosted: Mon Sep 07, 2015 9:55 pm
A correction: only 2 of the 7 slides I recently acquired from John Benson are Dick Wallin duplicates. 1 is a C.G. Parsons duplicate, and 1 is an Al Chione duplicate, which will be posted in the Al Chione thread. At this point in time, I don't know if the other 3 were duplicates made by John or by someone else; this includes the slide I posted above of the #364C at Tacoma. Also, I mentioned that I had previously posted 2 other slides acquired from John: UP #937 and AT&SF #M190. That number should have been 4: the other 2 were C&O 60' RPO #112 at Washington Union Station in 1965 (an original Kodachrome slide taken by George H. Menge) and UP 10RM-6DB sleeper #1427 Pacific Mist in Denver (another Dick Wallin duplicate slide).
Another slide:
F7A #274A and another A unit are the power for a short, 4 car westbound passenger train at Skykomish. This slide dates from sometime in the latter half of the 1950's, after the electrics were retired but before the catenary was taken down. This is another one of the three slides for which I don't know who the duplicator was, and of the 7 I acquired from John, this is the only one which isn't stamped with the brand. However, it is stamped: "Pallas Photo Labs Inc Chicago/Denver/Milwaukee".
http://www.rrpicturearchives.net/showPicture.aspx?id=4287012
Ted Brumberg
PostPosted: Tue Sep 15, 2015 10:25 pm
Another slide:
BN F7B #9709, still in Big Sky Blue paint. Built in August 1952 as freight-geared #460B, and in 1969 it was regeared for passenger service as #380B. After the BN merger, the #380B was renumbered with other passenger-geared units into the #97xx-series. Several years later, after Amtrak ceased leasing units and a number of E's were assigned to the Racetrack, the #9709 was renumbered/regeared again for freight service as #705. It was retired and sold to Precision National in December 1980. This is a Kodak-processed Ektachrome duplicate, but like several other slides purchased from John Benson, I don't know who made this particular duplicate, where or when it was taken, or who the photographer was.
http://www.rrpicturearchives.net/showPicture.aspx?id=4287015
Additions and corrections are welcome. Thanks in advance.
Ted Brumberg
PostPosted: Wed Sep 16, 2015 6:14 pm
Another slide:
GN SD9 #577. 1 of GN's first 6 SD9's (#573-#578), built in February 1954. These 6 engines were renumbered as BN #6100-#6105 (#577 to #6104), and this slide dates from after the merger, as 2 of the 4 ex-GN engines seen here have already received their new numbers. The #6104 was retired in September 1984 and traded in July 1985 to EMD on an order of GP50's. As for the other 3 engines: on the far left is freight-geared F7A #314C, which was built in April 1952, became BN #646, and was retired and sold to Precision National in April 1974. Behind the #577 is BN-renumbered GP9 #1832, which was built in May 1954 as GN #680, sold in October 1987 to MRL, renumbered #103, and then renumbered again to #127. Finally, in the far background is BN-renumbered, freight-geared F7A #644, which was built in April 1952 as GN #314A, and was retired and sold to Precision National in December 1980. This is a Dick Wallin Kodak-processed Ektachrome duplicate, and I don't have info on the date, location, or photographer.
http://www.rrpicturearchives.net/showPicture.aspx?id=4287013
Ted Brumberg
PostPosted: Sat Sep 26, 2015 3:21 am
Another slide:
GN GP9's #706 and #704 in Klamath Falls, OR, on June 7th, 1970. These were 2 of 8 GP9's (#704-#711) built in April 1956, and these 2 were later BN #1779 and #1777 respectively. The #1779 was retired in December 1990 and sold to National RY Equipment in February 1991. The #1777 was retired in February 1991 and sold to the Great Western RY in June as GWR #1777. It was later (when??) sold to Omnitrax as OMLX #1777, and then resold (when??) to Bay Colony Lines as BCLR #1705, apparently having been rebuilt as a GP9R. This a Kodachrome duplicate made by C.G. Parsons; no clue on whether or not Mr. Parsons was the photographer, or if it was someone else.
http://www.rrpicturearchives.net/showPicture.aspx?id=4287011
Sources:
1. Ben Ringnalda's Great Northern Empire website: http://www.greatnorthernempire.net/GNEThisMonthsFeature.php
2. The Diesel Shop roster page for Bay Colony Lines: http://thedieselshop.us/BAY.HTML
3. The Diesel Shop roster page for Great Western RY: http://thedieselshop.us/GreatWstn.HTML
Ted Brumberg
PostPosted: Sat Sep 26, 2015 7:21 pm
re: GN SD9 #577
GN Roundhouse Superior, WI
PostPosted: Sat Sep 26, 2015 8:43 pm
Thanks, Hudson, for identifying the location!
Here's the last GN slide I acquired from John Benson, a Dick Wallin duplicate of an A-B-B-A lashup on what is obviously the Empire Builder. While the location is not written on the slide mount, this appears to be somewhere in the Twin Cities area, but I don't know exactly where. The first 2 units are F7A #350A and F7B #364B. The #350A was built as a passenger-geared F3A in November 1947, and after a wreck, was rebuilt in June 1952 to a F7A, and was traded in to EMD in February 1966. The #364B was built in October 1950, and was later BN #9723. It was traded in to EMD in February 1972 on an order of GP38-2's.
http://www.rrpicturearchives.net/showPicture.aspx?id=4287010
Source:
Ted Brumberg
PostPosted: Sat Sep 26, 2015 8:58 pm
re: F7A #350A
St. Paul, MN, coming up the hill from St. Paul Union Depot.
Just before Westminster Tower.
Heading for Minneapolis.
-Hudson
