It is currently Thu Oct 29, 2026 6:26 am
 Post subject: Need Manual for Safety Car Motor-Alternator
PostPosted: Fri Feb 13, 2015 11:52 am
Does anyone have access to a manual for a 32VDC to 120VAC Safety Car Heating & Lighting Motor-Alternator?
I do not have the exact model # as it has worn off the name plate, but it seems to be a pretty standard one.
Here's some pix:
https://www.dropbox.com/sh/s33hl2q8oncy ... xWs7a?dl=0
Warren
x-5000.org
 Post subject: Re: Need Manual for Safety Car Motor-Alternator
PostPosted: Fri Feb 20, 2015 8:54 pm
I do not a Manual. At get Reverse Current Relay on your wires. That way idea to each section clean up the varnish,replace the screw,bolt,tight the lug,a the a time on do.
File comment: RCR
