It is currently Wed Oct 28, 2026 9:00 am
Post new topic Reply to topic  [ 265 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17, 18  Next
 Post subject: Re: 1948 Chicago Railroad Fair
PostPosted: Thu Dec 11, 2014 8:38 pm
Les Beckman wrote:
Steve -
In looking again at the last 4 of your Dad's photos, I noticed a couple of interesting things. Note that the E7 on GM's "Train of Tomorrow" carries the number 765 in the number board. Made famous today by a certain, currently operable, Nickel Plate Road 2-8-4. Wonder why that particular number for the E7?
Wonderful stuff!
Oh yes, wonderful indeed.
As to the number on the E7--"765" could be a reversed "567," the cylinder displacement for EMD's prime movers for so many years. Just speculation of course, but who really knows?
PostPosted: Thu Dec 11, 2014 10:38 pm
rlsteam wrote:
OK, great. I am copying most of these as they come. But maybe I need to wait till you have scanned everything before I add them to my RR Fair site.
There are quite a few photos so it is up to you. Just pick and chose.
"Those who don't know history are destined to repeat it"
Edmund Burke (1729-1797)
PostPosted: Thu Dec 11, 2014 10:41 pm
Les Beckman wrote:
Steve -
Quick question. Your Dad attended the Fair in 1948. Do you know if he also attended the 1949 version? I believe that C&O 2-6-6-2 #1309 was on exhibit there in 1949. Of course, the engine is now being restored to run on the WMSR. So, just wondering.
Yes he attended it in 1949 also. There are photos from both years.
PostPosted: Sun Dec 14, 2014 1:42 am
All photos from August 1949.
I counted 13 different rolls of film that contain photographs from the 1948 & 1949 Chicago Railroad Fair. Well over 100 images.
PostPosted: Sun Dec 14, 2014 11:33 am
Great work, Steve! Are all remaining slides from 1949, or are there still some 1948 views to come?
www.railarchive.net
PostPosted: Sun Dec 14, 2014 4:10 pm
There is about a 50/50 mix from 1948/1949. I took these out of order since you were interested in the turbine and I remember the Big Boy being in there. I can go back to the 1948 photos and finish them.
PostPosted: Sun Dec 14, 2014 11:06 pm
Steve, that would be good, if you could complete the 1948 set (because I have my web site photos organized by year). By the way, I took your dad's two 1949 slides of UP "Big Boy" 4022 and spliced them together, with this result:
www.railarchive.net
PostPosted: Mon Dec 15, 2014 1:11 am
Jeff Lisowski wrote:
Absolutely stunning photos!
Come to think of it - I have never seen a photograph of a Big Boy in Chicago. I have only seen photos of them out west. These might be the only photographs of a Big Boy in Chicago left in existence.
I really like the composite that rlsteam put together. I can't even tell where they are spliced.
PostPosted: Mon Dec 15, 2014 12:56 pm
The splice is behind the first sand dome, around the boiler on a seam, in front of the air reservoir, through the joint in the large steam pipe, in front of the second cylinder, and down a fence slat to the ground. Some cleanup and tweaking were needed, especially the shadow in front of the fence. But your father made it easy by taking both slides from the same position, so no resizing of the second image was needed to make it dovetail with the first. But you can see a slight bend in the running board, just above the air reservoir.
www.railarchive.net
PostPosted: Mon Dec 15, 2014 8:58 pm
After some study I did notice what you mentioned. What software did you use? It turned out very nice.
PostPosted: Mon Dec 15, 2014 9:26 pm
Just curious, what's on this site today? Anything remaining at all?
Lee Bishop
PostPosted: Tue Dec 16, 2014 1:20 am
I am using PaintShop Pro 7, an older program that was put out by Jasc Software but now is issued by Corel. I have the Jasc version. I have Adobe PhotoShop but I found it was too complicated to learn it when I already know the other program.
www.railarchive.net
PostPosted: Tue Dec 16, 2014 10:31 am
I assume you're referring to this thread and the missing images. I have transferred all the images from Facebook to photobucket and now I have to go back and figure which images went in which post. Facebook through the years has changed the address of nearly all my photos which is where I originally linked all the images to.
PostPosted: Tue Dec 16, 2014 11:10 am
Steve;
I took it to mean the site were the Railroad Fair was ... kind of wondering that myself. Is there anything currently on the grounds where the Railroad Fairs were held?
Tim W.
PostPosted: Tue Dec 16, 2014 12:45 pm
Yes, that is correct. Sorry, should have been more specific...
Lee Bishop
