It is currently Thu Oct 29, 2026 11:55 pm
 Post subject: Building a Locomotive in your Backyard.
PostPosted: Sat Aug 02, 2014 12:23 pm
There must be something in the genetic make up of Englishmen and their descendants
http://www.abc.net.au/news/2014-08-01/a ... ld/5642732
 Post subject: Re: Building a Locomotive in your Backyard.
PostPosted: Sat Aug 02, 2014 3:34 pm
Extremely impressive. I wish this man the best of luck in such an ambitious endeavor. I can't recall another instance in the preservation era aside from Dave Kloke and the Gramlings where individuals built full size steam locomotives from the ground up.
PostPosted: Mon Aug 04, 2014 12:55 pm
The only thing I can imagine that is more ambitious is building an airplane in your backyard. My dad built a high performance Thunder Mustang (3/4 scale P-51D)-took him ten years but he got it certified as an Experimental aircraft. That said, building a locomotive is inherently saner and safer.
PostPosted: Mon Aug 04, 2014 1:12 pm
Wow. Like the rest of you, I wish great success for this guy. He's really gotten a long way with this. I assume he'll have to farm out the boiler to someone. Would any licensing authority sign off on a boiler built by someone like that?
Lee Bishop
PostPosted: Mon Aug 04, 2014 1:23 pm
How is this different than what Kloke is doing?
PostPosted: Tue Aug 05, 2014 1:48 pm
Depends on what the licensing requirements are in his jurisdiction. I would think that most folks would prefer to purchase a commercially assembled boiler to save time and effort-then again, do it yourself folks are different. I suppose that the government inspector could sign off on it if the builder thoroughly documented each stage of assembly (ie. detailed photographs of welds, riviting) in addition to having the inspector do a detailed examination of the boiler. FAA does this all the time with homebuilt aircraft.
PostPosted: Thu Aug 07, 2014 7:43 am
I hae been to Spaulding,IL, and it really doesn't look much different (except for the heavy construction equipment outside the shed).
PostPosted: Thu Aug 07, 2014 11:24 am
So how does Kloke do his boilers? Obviously he has a solution for that issue.
PostPosted: Thu Aug 07, 2014 2:10 pm
He picks up the phone and orders them, although I don't know who from. They are modern boilers, from the design work the NPS had done for the engines at the Golden Spike park.
PostPosted: Thu Aug 07, 2014 4:18 pm
OK, the fact he has them built by an outside firm, and presumably one that can certify to the applicable code(s) is all that really matters. I was guessing that, but it was a guess.
