It is currently Mon Oct 19, 2026 2:51 pm
 Post subject: Re-coating a glass Pyle National headlight reflector
PostPosted: Tue Jul 22, 2014 2:34 pm
Does anyone have any information on how to re-coat the glass reflector from a Pyle National Headlight? We have a glass reflector that has lost its reflective coating and need to re-coat it for a locomotive restoration. Any ideas?
Thanks!
Jimmy Summers
Heart of Dixie Railroad Museum
 Post subject: Re: Re-coating a glass Pyle National headlight reflector
PostPosted: Tue Jul 22, 2014 3:54 pm
Perhaps a good start would be to locate a firm in your area that can re-silver a mirror.
Fred Heilich
PostPosted: Tue Jul 22, 2014 5:16 pm
Previous thread:
http://www.rypn.org/forums/viewtopic.php?f=1&t=35806&hilit=pyle
PostPosted: Tue Jul 22, 2014 7:57 pm
These folks in Seattle say they have re-silvered locomotive headlights.
http://www.hylitemirrorandglass.com/
Good luck
PostPosted: Fri Jul 25, 2014 9:04 pm
Thanks guys! This gives us some great leads!
PostPosted: Fri Jul 25, 2014 10:04 pm
I have a number for a lady in Kansas that can do them PM me for the contact information.
Mark Frazier
Florida Heritage Rail Inc
PostPosted: Sat Jul 26, 2014 2:31 pm
When you get this completed, please report how this all turns out.
Photos are also greatly apprecaited!
PostPosted: Sun Jul 27, 2014 12:01 pm
Checkout this link. http://angelgilding.com/A1111C.html
We have several headlights at the MOT in St. Louis that need re-silvering. I have not tried it yet but it looks like it would work. The kit contains everything you would need to clean and re-silver the headlight. I may try silver paint first to see if looks like real silver.
PostPosted: Sun May 01, 2022 3:19 pm
We have used Rustoleum Mirror Effect coating on several steam train head and tail lights with good results.
https://www.rustoleum.com/product-catal ... or-effect/
Cleaning the old coating off the back of the lens can be difficult. Hydrochloric acid works to remove the copper and the silver can be removed with a razor blade.
When the back of the lens is clean follow the directions on the can. We usually use a truck liner spray on the back to protect the paint.
PostPosted: Mon May 02, 2022 9:04 am
Paint stripper works to remove the paint. You might find steel wool and bleach to be more friendly to the glass surface under the silver. Some toilet bowl cleaners may work as well.
Bob
PostPosted: Mon May 02, 2022 10:18 pm
You could try Buffalo Precision Glass. If they can't do it they can probably tell you who could. They make new reflectors.
PostPosted: Wed May 04, 2022 7:17 am
Is there a way to recoat, or recreate the “golden glow”’ look?
PostPosted: Wed May 04, 2022 11:13 am
The Golden Glow lights were that particular color due to them being made of uranium glass which has a yellowish to greenish hue to it. The silvering on the back side wasn’t really any different from what you find behind regular clear glass.
This was discussed a bit not too long ago.
PostPosted: Sun May 08, 2022 2:07 pm
Here is one possible alternative: A friend's headlight was missing the reflector altogether, and replacemets were not available. He found an affordable stainless steel salad bowl with a roughly correct shape, bored out the bottom to clear the bulb and focusing hardware, with perhaps a few other minor modifications to fit in the headlight housing. It worked nicely and saved the expense and time to locate and re-silver an original.
Best regards,
Craig Cootsona
Owner, chief cook, and bottle washer at Pacifc Journal Pad LLC
PacifcjournalPadLLC@gmail.com
