It is currently Wed Oct 28, 2026 6:20 am
 Post subject: Re: Shop Lighting: Keep or replace mercury vapor?
PostPosted: Tue Mar 25, 2014 4:56 pm
We've had second hand MV lights in our shop for some time... about two years ago we bought a couple of the fluorescent screw-in bulbs for a couple of them (as they died). We did have to strip the guts of the fixture - remove ballast etc, and direct wire the 120 to the bulb, as I believe the bulb had its own integrated ballast. They are really nice; in the cold the come on instantly, though not full brightness; and they don't seem to mind being turned off then on in quick succession like the MVs do. While the bulbs might be a little more than the MVs, there are "less" parts to die - I forget the brand, but I think they were in the neighborhood of $100; but a nice way to recycle the fixture.
Dave
PostPosted: Tue Mar 25, 2014 5:48 pm
Another interesting question is, what did light fixtures look like in the 1920s, 1930s, 1940s... and what would it take to emulate that look, but in LED?
PostPosted: Tue Mar 25, 2014 9:07 pm
Some manufacturers offer retrofit kits for some of their products, for example Sentry Lighting. U.C. Berkeley has converted lots of Sentry's "Tulip" fixtures on campus:
http://www.sentrylighting.com/led-led-retrofit-108-108-142.html
I think that there would be a business opportunity for generic retrofit kits consisting of an LED array with an Edison (or Mogul) screw base and an omnidirectional pattern, and a driver module which could be installed in place of a ballast and would work on common voltages (110, 277, etc.). (By "omnidirectional" I mean circular perpendicular to the bulb's base but not necessarily emitting anything "upward" from the base.) A lot of existing fixtures have built-in reflectors which are still usable.
