It is currently Fri Oct 23, 2026 8:44 pm
 Post subject: Re: Snow, What Snow?
PostPosted: Sat Feb 15, 2014 12:03 pm
Standard practice on the railroad to operate tender first outbound from Strasburg.
PostPosted: Sat Feb 15, 2014 1:28 pm
Like Jim said above - the Strasburg has little other choice, but I was curious given such a choice, is one more preferable then the other?
/Mitch
PostPosted: Fri Feb 21, 2014 8:42 pm
Tender First. It's almost "historically accurate" for a shoreline railroad. Besides, all the engines are equipped with couplers in the front. Someone sure intended for engines to run backwards with trains back in the day. ;)
PostPosted: Sat Feb 22, 2014 12:15 am
Gary Gray wrote:
dinwitty wrote:
that is a classic shot...and a good engine to do it too, N&W 4-8-0's were the coal haulers and max out the weight on the drivers. We need an M2c restored...psst Gary Gray...
Send your check for $2,000,000 and I'll get started as soon as it clears.....
We could have your loki up and going for no more than 1.25....... Yes it needs a lot but not 2 mil worth.
Cheers, Jason ;-)
PostPosted: Sat Feb 22, 2014 1:33 am
Cheers, Jason ;-)
Jason, You know I always put in an "Oh S**t" factor.... it makes sure my projects come in on or under budget....
Gary
PostPosted: Sat Feb 22, 2014 9:18 am
Gary, is generally considered good business practice...... so, ditto.
Cheers, Jason
