It is currently Fri Oct 30, 2026 4:41 am
 Post subject: Re: Air Signal System Questions
PostPosted: Sat Nov 16, 2013 12:31 am
Bulby wrote:
So hear is what I would like to know: Amended based on replies
#1. Is the material in the book accurate? If not, where can I find the current information? Based on replies received, yes, it is accurate
#2. Current intention is to attach shop air to the system (if that succeeds, we hope to test the system with a locomotive this coming spring): are there any precautions we should take before charging the system (Note: This car has sat outside since arriving at IRM, but did arrive fully operational) Besides a reminder to check any and all air reservoirs with hammer testing and possibly hydro-statically; as well as visually inspect the entire line under the car, the only other suggestion has been that if we have a leak, using soapy water on the fittings will locate the leak when the line is under air pressure. Are there any other precautions that sould be taken?
#3. This text covers regulators and whistles in a steam engine; what, If any changes were made when the switch was made to diesel? Consensus is that the system did not change
#4. What precautions should be taken for testing the system with a (diesel) locomotive attached? Consensus seems to be that the biggest precaution is to ensure the pressure regulator is functioning on the locomotive prior to connecting to the car. What other precautions should be taken?
#5. Is standard practice to have a valve on the (diesel) locomotives that would have to be opened to allow this system to function? If so, where would it typically be? Consensus seems to be yes, with cut-outs between the regulator and the main reservoir, the whistle and the whistle actuator, and on the ends of the train line pipe. Am I missing any places for cut-outs?
#6. Information from someone in IRM's Diesel department indicates that the pipe should be charged to 90 psi, however the text linked above says 40 psi; which is accurate to post 1930? What about after steam was retired, but before passenger service ended on the Milwaukee Road? Based on postings, 40 psi is correct, 90 psi is merely the brake line
#7. In keeping with its role as a test unit; would it be conceivable for the car to be fitted with a signal whistle like what was fitted to the locomotives for the purpose of listening to the signals? If so, where should I look for this? How would I go about testing it? Still looking for suggestions here.
Red is answers, Blue is amended questions.
Catalpa wrote:
The current standard for testing passenger car air brakes or testing Conductor’s Air Signal Equipment refers to the following publication: Conductor’s Air Signal Instruction Leaflet No. 2377-2, July 1942. The publication is obsolete, but probably could be found in libraries or museum collections. I've seen them occasionally on E-bay. See Mike Tillger's post above if you need a copy
There was no whistle in the cars, as I remember. The source of air and signal whistle was on the locomotive. There are probably some passenger locomotives, either diesel or steam, in the IRM collection, which are equipped with the signal equipment, and there is no reason it couldn't be made functional. The thought was as a test car, they would have at least had reason to listen in on the Air signals
I understand that few if any, have been on the Dynamometer or seen drawings for it. If no one can provide evidence that the X-5000 would or would not have been equipped, can someone provide a counter to my logic?
PaulWWoodring wrote:
For those of us old enough to have ridden pre-Amtrak passenger trains, this is one of those aspects of restoration or re-creation that gets lost to history - like steam heat, friction bearing journals, Spicer drives, and axle generators. Some would say good riddance, some of us think that any operation that can recreate those things adds to the historic experience. I clearly remember as a child being in a vestibule of a passenger train (probably either B&O or EL), watching a conductor reach up and tug on a cord to give the engineer "two to go" after a station stop.
Frankly, this is a failure in historic preservation. I personally am far to young to remember passenger service before Amtrak. The only reason I gave thought to it even being an air signal line, was the caption of a photo that I saw online over 6 months ago. Before that I had never even heard of an air signal system. I have been interested in railways and their history my entire life, have racked up a long list of experiences for someone my age, and have been to museums across a wide swath of the country; Why haven't I seen more interpretation of this in museums? Even those that still use steam heat and interpret (which is just as, if not more important) that they do so, do not use air signals or explain what they are
I would like to say thank you to those who have offered advice and suggestions; they are proving invaluable in formulating a testing plan.
Restoring MILW X-5000: The Milwaukee Road's Dynamometer car
Restoration website
PostPosted: Sat Nov 16, 2013 1:09 am
I would expect that there is no whistle in the car, just a car discharge valve. If to many whistles are connected to the line it will not recover after being used and will blow continuously. I believe you can get away with two whistles cut in, three is too many, depending on leakage. The maintenance required is the car discharge valve will need a new rubber seat and maybe a spring. Both still available from WABCo last time I checked. The air hoses and glad hand gaskets at the end of the car will need replacing. If the angle cocks on the signal line leak, they will have to be repaired. Any leakage in the system will need to be repaired.
PostPosted: Sun Nov 17, 2013 1:14 am
Westinghouse Manual No. 5061 (March 1939) Westinghouse Train Air Signal System.
No 5061 March 1939 Westinghouse Train Air Signal System.pdf [699.2 KiB]
Downloaded 441 times
PostPosted: Wed Nov 20, 2013 3:13 pm
Bulby wrote:
Frankly, this is a failure in historic preservation. I personally am far to young to remember passenger service before Amtrak. The only reason I gave thought to it even being an air signal line, was the caption of a photo... Why haven't I seen more interpretation of this in museums?
Because everyone is too busy interpreting Pullman porters, the political origins of the Transcontinental Railroad, the Robber Barons, blah blah. All human interest stuff.
The American way is for tech to be magic, and subcontract all the gory details to the Chinese.
Just look at all the Civil War stuff. Everybody wants to interpret whether Meade was a coward. Nobody wants to talk about what a cannonball does to a skirmishing line.
The new American way is for tech to be magic, and subcontract all the gory details to the Chinese. Gadget don't work, whip out your Mastercard, you were due for a new one anyway.
 Post subject: Re: Air Signal System Questions/Historical Intrepretation
PostPosted: Thu Nov 21, 2013 1:52 am
Robert, I am going to assume you are challenging me to defend my statement. Below is my individual response(s).
Then we are not telling the whole story and failing to teach the public; which is a failure of the goal of preservation, why preserve something if you can't care for and then interpret it? Just because it doesn't seem to be immediately a "human interest story" does not mean that it is relegated to the dust bin.
Relevance? What a piece of metal propelled at extreme speed does to the human body is not an apt comparison to a device that furthered communication among train crew.
On the other hand, and to further defend my position, Lets pretend that we have a museum. We have an old civil war cannon that we want to display outside; but we also want to show controversies of the war that linger, we choose Meade. It could be argued that a proper interpretation of the Civil War cannon and Meade would include a section on the effectiveness of the war's modern artillery, how that may have affected the judgement of the general in his decision making, and how his decisions affect today's military officers. You should also throw in how the Civil War's artillery affects today's military artillery. That is proper interpretation. That is how you teach your visitors about what you are preserving.
Not to start a political debate, but isn't that a Green way of behaving?
Now to further my point using your statement. Historical preservation and interpretation: A savy museum board will see that there is something to be taught from this new attitude, how the attitudes of the past are different from today's. Our fictional museum has a shop where the pride of the line, ol' 777, a coal burning 2-6-2 from 1903 is maintained and stored between runs. Next to it is where we keep the museum's shop goat, a former EMD MP15 re-engined with 2 genset engines after the old main block cracked. A viewing gallery is being built in the form of a loft above the two-track shop. A good museum will explain how while the steam engine just had a boiler course welded because a crack had developed after 100 years of use, while the MP 15 has seen its main engine replaced by a pair of gensets after the main block had a small crack around a mounting stud, and then had a genset replaced because a piston got launched out of a cylinder. A good museum can further explain how this represents the different attitudes of the past and the present, seen in real time between the steamer and the diesel, and how what is essentially the same severity of problem would have been looked at differently.
Another example of interpration, doing it right: Let's say we are installing a new exhibit at our fictional museum on the history of the telephone and telegraph. We spend $300,000 of donated money to refit a baggage car with displays of old telegraphs and telephones. We make some of the machines interactive to get the kids to want to stop at it. We even post signs telling how old each one is and who made it. That is NOT interpreting the telegraphs and telephones to teach your visitors. You have only done half the work; now you must show them WHY they should care that this particular telephone came out when it did and why it was important to the development of the modern cell phone (if that is where our fictional exhibit ends). Until you can explain that adequately, and without completely losing them, you have failed.
While properly trained docents are good because they can adapt to their audience, poorly trained docents leave even the avid learner unlikely to return. Don't have the man power to spare to have docents or train them? Then develop adequate displays and signage that allows you to put your manpower elsewhere. Using IRM as an example, if IRM used docents instead of signage, how much work could get done to turn back time and erase deterioration? Yes, there are those who would stay in the shops, but how many volunteers would stay, if most of what was their day was explaining something over and over? Some may like doing this, while others will hate it and leave. How many new people would be attracted to volunteer? I don't think many would be.
Restoration website
PostPosted: Thu May 22, 2014 3:56 pm
Bumping this old thread, Catalpa; you have a P.M.
As an update on this project, 1 air signal hose has been hung on the car; and the system proven to hold pressure. I may post photos after this weekend.
Restoration website
PostPosted: Thu May 22, 2014 8:37 pm
2 toots, thats a go, got it...
