It is currently Fri Oct 30, 2026 1:46 pm
 Post subject: Baldwin order number
PostPosted: Mon Nov 04, 2013 7:49 pm
Does anyone know what the order number for baldwin construction #60450-60494 would be?
Thanks for any help!
Stuart Harrod
Steam shop machinist
Nordsjællands Veterantog
Veterantoget.dk
 Post subject: Re: Baldwin order number
PostPosted: Mon Nov 11, 2013 12:34 am
Pennsylvania State Archives in Harrisburg, PA has many Baldwin records including order books. I don't know about the numbers you are asking about. You need to contact them directly.
RWJ
PostPosted: Mon Nov 11, 2013 11:18 am
Perhaps additional info may help find the order number-from the digital Collections of the DeGoyler Library Vol. 80 pg. 731
PostPosted: Tue Nov 12, 2013 12:15 am
Wow Mike, all I can say is wow. Thank you so much! This is exactly what I was looking for and more! hopefully this will speed up my time researching at RMofPA next summer!
Stuart Harrod
Veterantoget.dk
PostPosted: Tue Nov 12, 2013 1:03 am
Are you looking for a Southern 2-8-2?
PostPosted: Tue Nov 12, 2013 12:56 pm
Don't know what 10stewi is looking for, but some interesting lokeys on this list. How about an Illinois Terminal 2-6-0 new in 1928? Or a Woodward Iron 0-4-0; I thought that outfit only had "big" engines? And what does the "E" signify after a few of these locomotives?
Thanks for the posting!
PostPosted: Tue Nov 12, 2013 4:13 pm
The "E" stands for Electric. At this time BLW assembled and tested most of the electric mine locos sold under the Baldwin-Westinghouse name. The bigger electrics were completed mechanically at BLW then shipped to the Westinghouse East Pittsburgh Works for installation of the electrical gear and track tests. A few larger locos were done at BLW, but as a rule WECo did those at E. Pgh. Mine locos didn't rate a track test at BLW, they were just run on a set of rollers.
PostPosted: Tue Nov 12, 2013 8:48 pm
Hey Austin,
Thanks for your submission! Unfortunately that was an order for two locomotives that were just plain old Southern locomotives. Its only an order of two because they were fitted with a tender booster on the second tender truck. Thanks for contributing your piece though!
Stuart Harrod
Veterantoget.dk
