It is currently Tue Oct 27, 2026 1:35 am
 Post subject: ATSF 108 Restoration at Orange Empire Railway Museum-Update
PostPosted: Fri Nov 01, 2013 11:04 pm
The straightened and repaired equipment access doors have been rehung on the superstructure and the crew is nearly finished installing replacement car body panels.
Panels rest on lugs that are welded to the superstructure frame. Aluminum extrusion battens retain the panels in compression, separated from the carbon steel panels by neoprene gasketing. New batten replicas were formed at an extrusion shop then at the Museum, they were cut to the various lengths required and milled at the places where they bridge the panel support lugs. The vertical battens are capped at the top and bottom. Caps were cut from flat stock, TIG welded to the vertical extrusions then hand worked to blend an edge radius. The many, many attachment hardware holes were accurately located using dimensions from the original drawings then located for drilling using an indexing plate set up on the table of a single spindle drill press. Only a couple of holes were off, just slightly. Considering accidents and the corrosion that occurred over the locomotive’s service life, that is amazing.
Retro 'engineering' continues to restore such as-built features as classification lights, inside access to the number board lamps and the steam generator hatch vent and exhaust stack.
As a result of an accident, 108 received a plow in place of its distinctive F/ FP45 pilot. The contour sculpted pilot is sort of a heritage link to predecessor full width car body Electro-Motive 'E' and 'F' design and so a pilot was 'hunted down' securing a key visual element needed to depict the locomotive as it was delivered to Santa Fe in December, 1967
File comment: Finished Battens
File comment: Batten Drill Fixture
File comment: Panel Installation
 Post subject: Re: ATSF 108 Restoration at Orange Empire Railway Museum-Upd
PostPosted: Sun Nov 03, 2013 6:45 pm
Nice work. Appears that there is more to these types of carbodies than meets the eye.
Dave
PostPosted: Fri Apr 07, 2017 8:26 pm
Please note, the thread above is from 2013.
An update on ATSF 108 was posted on Trainorders today, 4-7-17.
TomPlatten wrote:
... SF 108 being pulled out of carbarn 7 to facilitate the reinstallation of the dynamic brake hatch by Jeff using his large crane. Another big step! Now the only missing component is the turbocharger which is going out for rebuild!
http://www.trainorders.com/discussion/r ... ?1,4266679
