It is currently Fri Oct 30, 2026 1:10 pm
 Post subject: Conrail Historical Society "Buy A Board" Fundraiser
PostPosted: Mon Oct 28, 2013 8:37 am
Help the CRHS restore It's G36L Class Gondola by buying a board and associated hardware! Your tax deductible donation will provide the following to get a floor back in our Gondola:
--1x 2"x10"x9'6" White or Red Oak board
--4x Decking Clips to secure the board to the car
--2x 10' "I" Beam sections to support the board
--Bolts, Nuts and Washers to secure your board to the car
--Transportation of materials to Topton Work Site
(Our gondola with the old damaged steel floor and broken stringers removed)
What do you get from this fundraiser?
-A receipt from the Conrail Shoppe that shows you made a tax-deductible donation (contact your tax professional to find out how this can effect your tax situation)
-We will dedicate space in the Conrail Quarterly with a picture of the car (and it's new floor) upon completion with your name listed as a donor
-The satisfaction of knowing you helped restore a piece of Conrail History!
(CRHS volunteers remove broken panels from the car. Some of the undamaged floor is being used to replace these panels)
Boards are $39.50 each and you may add as many to the cart as you wish!
This flooring will complete Phase 1 of the car work. To date, volunteers have removed the damaged steel floor, removed 3 damaged side panels, cut and shaped some of the undamaged sections of the old floor to become the new side panels and made minor other repairs. Phase 2 of the restoration, scheduled for fall 2014, will entail repair to grab irons and sill steps, sandblasting and painting. This will complete this restoration project.
It's easy to make your donation, just go to our online store (The Conrail Shoppe) at:
https://conrailshoppe.com/content/Make- ... ur-Gondola
We appreciate your donation!
 Post subject: Re: Conrail Historical Society "Buy A Board" Fundraiser
PostPosted: Sun Nov 17, 2013 6:05 pm
Just wanted to give an update..
We just passed the halfway mark on our fundraiser. Last Friday, 3 CRHS volunteers secured 1,350 Lbs of 4"x4" "I" beams to replace the old broken stringers in the gondola. These I beams run the length of the car on either side of the center sill to support the floor. They will be installed in the car as soon as our 21165 caboose paint job is complete and we can move the car inside. (although if there are projects that come up ahead of it, we may have to put it off until later...)
The steel (and eventually the deck boards) is stored inside a secure place until they'll be made ready for installation.
Thanks to all from this board who've donated (and all those who will!!)
Russ Swinnerton
CRHS Vice President
