It is currently Wed Oct 07, 2026 8:27 am
 Post subject: Parts Needed for Whiting Car Jacks.
PostPosted: Sat Aug 10, 2013 10:29 am
The jacks are 12 1/2 ton portable electric car jacks manufactured by the Whiting Corp of Monee, Ill 60449. They were built in 1987. Serial #s MXV -116 to 123. Our broken jack is # MXV-121.
The needed part is called a Winsmith 8CVDMW reducer. A new replacement part exceeds the funds available. I am hopeful of finding a used replacement part out there.
Wesley
 Post subject: Re: Parts Needed for Whiting Car Jacks.
PostPosted: Wed Aug 21, 2013 12:07 am
A little more information please on what your part is. I rebuilt the mechanical portions of 35 ton jacks and did not see such. An electrician of the railroad replaced all of the electrical components and was able to save a lot of money using his own sources. I bought Whiting parts when I had to, but was able to rebuild many of them.
A wise man will hear and will increase learning and a man of understanding shall attain to wise counsels: Prov. 1.5
PostPosted: Fri Aug 23, 2013 1:18 pm
were built in 1987 for the New York Rail Car Corp under requisition #79282-83 (1987)
The needed part is called a Winsmith 8CVDMW reducer (item 17 on attached drawing
U-89403). I have attached drawing U89403 and photos of the reducer and the jack.
steamerdave,
Here are some images. Please PM me and I can put you in touch with someone who has more details about the damaged reducer.
Wesley
File comment: Reducer is #17 on this drawing.
U-89403.TIF
PostPosted: Sun Aug 25, 2013 11:17 am
Contact Winsmith directly at:
http://www.winsmith.com/
Mike Tillger
PostPosted: Sun Aug 25, 2013 8:08 pm
Mike,
We've already talked to Winsmith.
I am waiting to hear from steamerdave.
Wesley
PostPosted: Sun Aug 25, 2013 8:30 pm
Sorry Wesley, I assumed you meant the price from Whiting with their markup was too high, and I thought maybe buying the parts directly from the manufacturer might be with in your budget. Good luck with your search.
Mike Tillger
