It is currently Fri Oct 30, 2026 7:51 pm
 Post subject: On the 3 Axle with 3 motor 1600 HP
PostPosted: Fri Jul 19, 2013 7:55 pm
Hi Fellow;
An a RSX-4 MRS1 the 3 Axle an 3 motor the space for rail could 4'8 1/2",5'0",5'3",an 5'6".
This axle an frame should have the same distantly an similar for just standard gauge which 1600 HP.
http://www.rr-fallenflags.org/manual/manual.html Then
ALCo Truck Maintenance Manual
http://www.rr-fallenflags.org/manual/MI-1010.pdf
The look at 1600 HP with 3 Axle and 3 motor.
Do anybody measure the space between the 3 Axle and see if the spaced to (1) Axle to middle (2) Axle is 6'-11" the loading pad and from middle Axle to (3) Axle it 5'-7" with has swivel plate.
I need distant from swivel plate to middle (2)Axle an 5'-7" to see I
can use standard gauge instead multi-gauge,I also need see where load pad from middle (2) Axle in 6'-11".
This could save money:
No buy long Axle.
Get roller bear,Do not that box a modify.
I do not Traction motors, The unit equipment type 5GE731F1.
The for complete except Traction motor.
I need to know the 1600 HP and 3 motor is O.K., an Where,What type
Locomotive that on.
Stan
