It is currently Fri Oct 30, 2026 9:47 pm
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Throat Sheets and Engineering Philosophy
PostPosted: Tue Jun 25, 2013 9:02 am
Related, possibly - Puffing Billy Railway.
The riveted boilers on the NA locomotives were customarily replaced with new riveted boilers fairly frequently - memory says 10 years of service, but i may be wrong there....so, sometime in the late 20th century they started building welded boilers rather than riveting them. Come the first life cycle changeout expected, they were pleasantly surprised to find out that only the firebox of the welded boiler needed to be replaced, the welded shell was still good.
What I don't know is how the welded parts were formed and joined. My guess is the corners were flanged at the throat and backhead and in the firebox, but I don't know about the dome, door hole and FTS. I've asked a friend from there to fill me in if possible. Maybe somebody here knows?
In any case, if I were to be building a new boiler today, I'd want to use flanged corners wherever possible and match the thickness of the materials to the specifications for the riveted original to the extent that it is possible. The 100% efficiency for the welded seams would just be additional margin from that perspective, and it would probably be considered overbuilt, but unless water quality or other issues were involved, i think it would lead to a longer in-service life made that way.
PostPosted: Tue Jun 25, 2013 11:09 am
Yes the PBR boilers do have rounded corners, a firebox door ring. Can't remember how the dome is mounted. These boilers are how welded boilers should be.
And in general terms that's how I would do a welded boiler with a few other things added in.
PostPosted: Tue Jun 25, 2013 6:50 pm
Under ASME are new, welded boilers required to be stress relieved? I had heard that this was no longer mandated but can't find anything on-line to verify this.
Thank you.
PostPosted: Wed Jun 26, 2013 11:18 am
Thank you.
Not necessarily, Table PW-39-1 Mandatory Requirements for Postweld Heat Treatment of Pressure Parts and Attachments - P No. 1 General Note (a), "Postweld heat treatment is not mandatory for P-No. 1 materials under the following conditions: (1) when the nominal thickness of a weld as defined in PW-39.4 does not exceed 3/4in. and a minimum preheat of 200° F is applied when the nominal material thickness of any of the base metals in the weld joint exceeds 1in." P numbers refer to the chemical composition of the alloy being welded. P-No. 1 materials are carbon steel such as SA-285-C and SA-516-70, two typical types of boiler plate.
There are other exemptions for thicker welds and thick materials, but there are tighter restrictions.
It is important to understand the transformation base metals go through and the stresses induced by welding when making the decision to stress relieve (postweld heat treat) a weldment or not. I would certainly want to heat treat the firebox and wrapper sheets after assembly, all those staybolts will be under enough stress in service, no need to start life that way.
PostPosted: Wed Jun 26, 2013 12:24 pm
Mark Jordan wrote:
... Some manufacturers of Scotch Marine boilers use flat sheets and some use flanged sheets, but I've not paid attention to see which one last longer.
... The design of the Morrison (corrugated) Tube is meant to deal with the expansion, but it still is not completely mitigated.
Mark, you referenced Scotch marine boilers and Morrison furnaces in the same post. Now I'm foaming, have lost all frame of reference and forget what this thread is about ...
PostPosted: Wed Jun 26, 2013 12:58 pm
Do not be mislead regarding Table PW-39. Post heat treat is still mandated for pressure vessels in general in the P-1 group. PW-39 lists a few exceptions and is very specific. For instance if there is a longitudinal seam you must heat treat. Fireboxes and wrappers are not excepted from heat treat. If you are contemplating construction of a new boiler using an "S" stamp plan to heat treat it.
Chris DeWitt
PostPosted: Wed Jun 26, 2013 1:38 pm
Chris DeWitt
Respectfully, can you point me to the paragraph that requires all longitudinal joints in P-1 material be postweld heat treated? I am not saying it isn't there, only I have not been able to find it.
Thank you.
PostPosted: Wed Jun 26, 2013 6:23 pm
First of all the code is a document of exclusions. This means that if a detail isn’t specifically excluded in writing then all the general rules apply.
That said, reading PW-39.1, it says "Except as provided ... in the notes within table PW-39.1...all welded pressure parts of power boilers shall be given a post heat treatment at a temperature not less than that specified in table PW-39.1."
The notes exclude circumferential seams and tubes and sundry. There is not specific exclusion for longitudinal seams. Of course you can argue with your ASME representative but if you can’t point to a specific exclusion by name it’s a waste of time.
So the bottom line, saying “I didn’t see it in the code so I can do it” doesn’t work.
Chris De Witt
PostPosted: Wed Jun 26, 2013 9:42 pm
OK, so a new welded locomotive boiler (with nice flanged corners) should be heat-treated after completion. I seem to recall that Alco had the large heat-treating (annealing?) oven, and that was one reason Alco produced the welded boilers for post-1940 steam power.
With that large chamber gone, what would acceptable post-assembly heat treatment be? Strip heaters and insulated blankets ? That's what was used on submarine hull weld joints in 1974, USN 688-class boats. I still have my Tempilsticks somewhere.....
PostPosted: Wed Jun 26, 2013 10:30 pm
Seems like there is plenty of heat treating capacity around. Here are a couple of local firms that came up on a quick search:
http://www.ic.gc.ca/app/ccc/srch/nvgt.d ... 2&app=sold
http://www.aberfoyle-mt.com/
Thank you for the information re ASME requirements. Sorry if I have led this thread astray.
PostPosted: Thu Jun 27, 2013 12:25 pm
One other thing; If you think that the code is inadequate or doesn’t make sense, or you want to do something not provided for in the code you can ask for an interpretation by letter (appendix 1) They will reply and some are printed and distributed as an addendum to the code. Most of them make good reading. So there is recourse if you want to fight with them
PostPosted: Thu Jun 27, 2013 7:26 pm
While earning my BSME in the late 80's I was able to perform a FEA on a live steam boiler I designed similar to what would be found on a RRSC mogul, very colorful!
I was also able to perform a destructive tensile test on a 1.125 in. threaded staybolt. Percent elongation was nothing like the lab instructor had ever seen before and he was quite interested in what material it was as he had never heard of wrought iron before. We also cut and polished a piece to look at, again amazed lab instructor. We also tested the modern equivalent of staybolt steel, and it snapped with a with a hardy "ping"!! The wrought iron bolt came apart like laffy taffy.
A couple of years later I came to appreciate the ease at which wrought iron is to "work" with an air hammer. To bad you cant get it anymore.
PostPosted: Sun Jun 30, 2013 10:30 pm
There are several topics in play.
Firing rates:
In the 1990's, the boiler manufacturer's argued that the pounds/hour firing rate was too restrictive when dictated by a table. The ASME Code was changed such that the manufacturer determined the steaming capacity. What happened was the 125 BHP boilers got 150 BHP burners and instantly, an advertising price war started. Of course the boiler life dropped from "almost forever" to "about 15 years or less".
Post Weld Heat Treatment:
The Code notes for PW-39 used to say "not required for circ seams in pipe, tubes and headers, 3/4" or less". More than a few companies got caught on this one. If they used a piece of pipe for a shell or furnace, they claimed that PWHT was not required. It is the use that dictates Code requirements. A Furnace is not a Pipe, regardless of what is the material is. Similarly, a SHELL is not a pipe, even if it started life as a pipe. Circ seams WERE required to have PWHT. Not long after the ASME conceded to lower the factor of safety to 3.5, to compete with Europe and Asia, the ASME modified the notes of PW-39 to what Paul Boschan quoted. Basically eliminating PWHT for boilers made of 3/4" and less thickness P-1 materials. Now boiler life has dropped from "about 15 years" to "how good is your water treatment".
PostPosted: Mon Jul 01, 2013 6:38 am
Flanged corners are not stronger, they are more RIGID. Quantitatively borne out by the Code by the attached Figure. Flanged corners allow the supporting pitch of stays to be the calculated pitch of the sheets PLUS the radius of the flange. For the square corner the max is P/2+2".
From a geometric stand point the resistance to bending of the flange is the same as the second profile.
Since the section thickness gets thicker the resistance to bending starts to increase at the beginning of the flange. Whereas the square corner allows the bending resistance of a uniform thickness beam.
PostPosted: Mon Jul 01, 2013 6:48 am
Continued:
The practical implication of this is shown in this photo of cracks in a rear tube sheet knuckle. Notice the cracks start at the beginning of the flange.
Probably the most dramatic instance I have seen of stress corrosion cracking that still passed a hydro. (Not the same boiler as above.)
