It is currently Sat Oct 31, 2026 2:26 am
 Post subject: Another from Shorpey's "The Hiawatha"
PostPosted: Thu Apr 25, 2013 2:56 pm
Nice observation car shot in the station.
www.shorpy.com/node/15152?size=_original
 Post subject: Re: Another from Shorpey's "The Hiawatha"
PostPosted: Thu Apr 25, 2013 8:11 pm
http://www.shorpy.com/node/15152?size=_original
Richard -
Nice photo. Very historic. The horn (for back up moves I assume) is interesting. I wonder if other round (or square) end observation cars normally had horns.
Thanks for the posting.
PostPosted: Thu Apr 25, 2013 10:39 pm
FO 261's Cedar Rapids still has an operational air horn activated from the interior in the round end.
Don C.
PostPosted: Fri Apr 26, 2013 9:14 pm
The problem with the Milwaukee cars is that the conductor was stuck inside. No rear door. I'm sure he had control of the air.
As an aside, PCC cars have a controller at the rear end for back-up moves.
Marty Bernard
Boomer Volunteer
________________
PostPosted: Fri Apr 26, 2013 9:21 pm
With a back door the conductor (rear-end brakeman) could use a peanut whistle on the air hose for example.
Marty Bernard
Boomer Volunteer
________________
PostPosted: Sat Apr 27, 2013 2:21 pm
Speaking of horns on the rear of tail cars...
Here is what was hiding behind the skirting on the rear of the Gulfport, an Illinois Central Panama Limited round-end obs.
And inside the car, showing gauge, signal line valve, horn valve, and conductor's valve.
