It is currently Sun Nov 15, 2026 10:26 pm
 Post subject: Re: 4501 Update 02-11-13
PostPosted: Fri Feb 15, 2013 9:59 pm
Great and detailed response Mark!
Cheers, Jason
PostPosted: Fri Feb 15, 2013 10:35 pm
Are the problems with 4501's Hodges trailing truck the same as every other Hodges trailing truck, or is it just because it is an earlier version of the trailing truck?
Stuart Harrod
Steam shop machinist
Nordsjællands Veterantog
Veterantoget.dk
PostPosted: Sat Feb 16, 2013 12:53 am
Mark,
If that response were on Facebook I would click the "like" button. A nice answer that sums up the facts, and disputes the argument without question.
PostPosted: Wed Feb 27, 2013 10:17 pm
Indeed, a very interesting fact. Odd, really.
Makes one wonder......
By the time the 4501 was built, it was clear that steam may not be the clear future for the Southern.
Mark, do you or would you suspect that cost was a factor? Machining the dead blocks into the frame is a labor cost.....by far cheaper to to mill out the frame minus the blocks, then include them after. I would believe that this may be part of the answer....not so much which was better or more effective, simply what was cheapest? Spending large amounts of $$$ on steam this late in the game?
Thoughts?
Don't have a firm answer why, just my gut says, "don't weld them." However, as is posted, the point Mark made is hard to dispute.
Mark seems to me that even you question what is really best? Tough question, really.
Just happy to see you doing the work and bringing 4501 back.....welded or not, great work!
Cheers,
John E. Rimmasch
Wasatch Railroad Contractors
PostPosted: Wed Feb 27, 2013 10:44 pm
John E. Rimmasch wrote:
Indeed, a very interesting fact. Odd, really. Makes one wonder...... By the time the 4501 was built, it was clear that steam may not be the clear future for the Southern.
4501 was built in 1911. How would the Southern not have been considering steam? The Southern ordered new locomotives up to 1928 and rebuilt/modernized them to keep them running up to 1952. Internal combustion was not even practical for another 2 to 5 +/- years.
Stuart Harrod
Veterantoget.dk
PostPosted: Wed Feb 27, 2013 10:52 pm
4501 was built in 1911. How would the Southern not have been considering steam? Internal combustion was not even practical for another 2 to 5 +/- years.
I think Mr. Rimmasch may have meant "rebuilt," as in the 1940s when the 4501 got some new frame parts.
All this reminds me--In Alfred W. Bruce's "The Steam Locomotive in Americal," he mentions that some engines would develop a settling to the rear. Bruce said such a locomotive was "ornery," with springs and equalizers going badly off level in the process. I can't help but wonder if such unfastened or loose connections between the equalizing system and the frame were the cause of this.
PostPosted: Wed Feb 27, 2013 11:04 pm
Ok! Thank you for explaining this to me J3a-614! I am sorry if I offended you John.
Stuart Harrod
Veterantoget.dk
PostPosted: Wed Feb 27, 2013 11:54 pm
To clear the waters.....
No offense taken. Based on what Mark had posted, I assumed that the 4501 was part of later or even the last order of this class. The last orders of any class usually spelled out the fact that the RR was considering alternative styles of motive power, meaning bigger steam or even diesel. Indeed, I used the D word in my post, which, indeed, may not have been the case. However, larger, or different models of motive power may have been a determining factor for the Southern. To be very honest, until the last post, I was unaware of 4501's actual build date. I thought it was in the 20's but was not sure.
However, for lines like the UP (which I know a bit better) Steam was not the primary choice of motive power, even in 1930. Wars, rumors of wars and actual wars caused the UP to consider motive power that they otherwise would not have chosen on their own. (The Big Boys are a classic example). Even for the Southern in 1911, Material and supplies, timing and availability, limited man-power and so on may all have been factors. Who knows?
I enjoy these civil discussions of the past!
Very kindly yours,
JohnE.
John E. Rimmasch
PostPosted: Thu Feb 28, 2013 12:36 am
4501 was actually FIRST of class for Southern.
PostPosted: Sat Mar 09, 2013 9:20 pm
A bit out of date, perhaps, but a reminder of the work that goes into keeping steam running, including our beloved 4501:
Tire removal. Two things stand out, at least for me. One is that the work must have been mighty hot that day--whew! The other is how quiet the shop seems. I've been in and worked in factories that seemed louder. Of course, this isn't to say that your ears aren't going to be affected by the noise that is there, but again, compared with a factory with an assembly line, or a big electric power station, this video and others I've seen of Chinese engines undergoing overhauls, seem peaceful, and not that noisy.
http://www.youtube.com/watch?v=542H11Tj2Wo
From just over a year ago--this would be loud! Riveting in the mud ring and firebox sheets:
http://www.youtube.com/watch?v=0joAAc0NiKE
Be nice to see a break-in run like this reenacted sometime. How many faces do you recognize in this one?
http://www.youtube.com/watch?v=E5iB-brCMgk
