It is currently Sat Oct 24, 2026 10:45 pm
 Post subject: Re: Reading and Northern 425 running in 2013?
PostPosted: Tue Jan 15, 2013 10:34 am
Do we know if her cylinder(s) was/were repaired?
PostPosted: Tue Jan 15, 2013 1:56 pm
G. W. Laepple wrote:
You do mean Route 896, right?
I did mean 896, thank you. My brain moves faster than I can type, and I often hit submit without checking first hahah
Mark Z. Yerkes
Amateur Rail Historian
PostPosted: Tue Jan 15, 2013 2:02 pm
Rodney A and F dorms have windows overlooking the B&O Royal Blue route, but F is where they start blowing for the Main Street crossing. Some of the Dickinson dorms overlook the main, too.
If you're in shape, you can make it to the W&W by bicycle in about 45-50 minutes.
You just answered a question I've had for a long time, but never got around to asking. I always assumed the line was ex-PRR due to its proximity to Philly, but the Royal Blue line? That's awesome.
Mark Z. Yerkes
PostPosted: Wed Jan 16, 2013 2:41 am
Its a 60 mile drive from Wilkes-Barre.
Ed K. cp Laurel Run
File comment: Blasting out of Port Clinton!
Edward J. Kaspriske
www.dieselairhorns.com
PostPosted: Wed Jan 16, 2013 5:16 am
That is such a dramatic photo. The 425 is a great sounding, great looking locomotive.
Chris
The Norfolk & Western...home of the A's,Y's,M's,K's and the Mighty J's....well done Roanoke....well done.
PostPosted: Wed Jan 16, 2013 9:39 am
You..... I...... um..... (O.o)
[impersonates Jay Leno's cameo appearance on "The Simpsons"]
"Someone get this kid a railroad atlas!!!"
The former PRR line, now Amtrak's and also used by SEPTA and NS, is down south of the main campus, with the former PRR passenger station still down under the overpass.
Now, if you want to get more interesting, I'll tell you about the Newark & Pomeroy, which went from Delaware City through to Pomeroy, Pa. by way of crossing the PRR main at what is now Davis Tower, then cutting north through town, crossing Main Street at the Newark Shopping Center and continuing north under the B&O to Landenburg, Pa. There's now a Pomeroy & Newark Bike Trail over much of the route, a trail I'm overdue to ride.
PostPosted: Wed Jan 16, 2013 1:55 pm
6-18003 wrote:
No, I am saying that 425 may be the only game in town.
Don't we count?
I steam, therefore I am.
Oh yes Kelly,
Make that the #90 with the Reading 6-chime passenger whistle, IMHO the BEST whistle tone out there! ;-)
Randy Musselman
PostPosted: Wed Jan 16, 2013 3:07 pm
Lets go even further off topic. I think I read it here a really long time ago that 89's whistle is 90's Great Western whistle. Is there any truth in that?
PostPosted: Wed Jan 16, 2013 4:12 pm
I think 89 has a Canadian 3 chime. BRW (GW) #60 has a Crosby (or similar) 3 chime which is similar to PRR 3 chimes. Perhaps similar to the Canadian? No idea if 60's whistle is original, but maybe this line of thought explains that line of thought. I don't know.
Daniel Kelly
PostPosted: Thu Jan 17, 2013 9:54 am
Let's get back on topic.
Is there anyone out there who is brave enough to answer whether or not the 425 received any cylinder work? I.e liners bored or perhaps replaced?
DC
PostPosted: Thu Jan 17, 2013 7:20 pm
Just new rings for now. Why fix everything while it's apart when you can tear it apart again? Makes sense to me...............................NOT!
The feed valve is your friend.
PostPosted: Thu Jan 17, 2013 10:18 pm
Maybe that's all it needed? I think at the time it was announced they were not sure what would be involved.
PostPosted: Fri Jan 18, 2013 11:39 am
I like the way you think!
Using brand new rings in a scored bore or a bore that exceedingly oval is a really won't fix anything. It will only expedite the wear on those new rings. We'll see how well it does though!
PostPosted: Fri Jan 18, 2013 2:40 pm
Two things: it is useless to speculate on repairs necessary if you don't know the extent of wear or damage; and, new rings can be fit to oval bores and serve adequately for a while. I helped Jack Andewrson fit oval rings into Humpy the Climax many years ago, and learned a lot.
I've never seen any real explaination of the real condition of the cylinders that are under discussion, and it isn't my business anyhow. All I know is I don't know enough to form (or express) a valid opinion. It is more than likely that the people in charge with greater knowledge and no lack of expertise have valid strategies of their own and are carrying them out.
Not every repair needs to result in like new condition. Sometimes it is enough to make things work for a while until a larger plan for overhaul makes it sensible to do more intensive work as part of an organic program.
Just happy to see her come back to life.
