It is currently Thu Oct 29, 2026 3:50 pm
 Post subject: More F Units for NS?
PostPosted: Wed Dec 19, 2012 12:05 am
Secondhand report from "Altoona Works" on Facebook indicates that Norfolk Southern has acquired longtime National Railway Equipment (Dixmoor and Silvis, Ill.) denizens CN F9A's 9177, 9164, and a third unit.....
Hey, I'll believe that over some Big Boy rumor any day.
 Post subject: Re: More F Units for NS?
PostPosted: Thu Dec 20, 2012 4:24 pm
Update from the same Facebook account:
The three units coming from NRE were reported incorrectly. They're now confirmed to be two F7As and an F7B.
First up is former C&NW F7A 407, that's been relettered as SOU 407.
http://www.rrpicturearchives.net/showPi ... id=1437152
Second is former CP Rail F7B 1019, it has been relettered as SOU 1019.
http://www.rrpicturearchives.net/showPi ... ?id=148076
Finally, there's former CN F7A 9177, it has been relettered as SOU 9177.
http://www.rrpicturearchives.net/showPi ... id=1153073
Info courtesy of Kenneth Larson and is confirmed in UMLER.
Supposedly, they'll become NS 4272-4274 after rebuild. All three will require extensive rebuild, including upgrade to EMD 645 engines as was done to the current quartet of NS "Executive F's". the CP B-unit is reportedly only a road slug at this point. The 407 has already had a hole cut in the engineer's side rear section.
PostPosted: Thu Dec 20, 2012 8:39 pm
If it is NS's intention to make the B unit a locomotive then its correct number was CP 4462. If on the other hand it is to be a slug or a HEP car then 1019 would do.
PostPosted: Thu Dec 20, 2012 11:02 pm
"the CP B-unit is reportedly only a road slug at this point. The 407 has already had a hole cut in the engineer's side rear section."
Juniata is a magical place. None of that is a problem for them. I'm betting they'll come out as three fabulous locomotives. I would love to tour the shops some day. Do they ever have open days there?
