It is currently Thu Oct 22, 2026 5:01 am
 Post subject: ALCo RS-2 Cab
PostPosted: Tue Nov 13, 2012 4:06 pm
Hello all, i am looking for photographs of the ALCo RS-2 cab interior, specifically as many views as possibly because i am looking for reference photos for a 3D model.
Also, does anyone know which horn was used on the ALCO RS series? many thanks.
Ship IT on the Frisco
 Post subject: Re: ALCo RS-2 Cab
PostPosted: Tue Nov 13, 2012 10:54 pm
Which horn depends on which railroad. If you can give us a specific locomotive model and line I might be able to help. I would guess that at one point in time or the other, an Alco RS series locomotive has worn essentially every model of horn produced in the last 60 plus years.
ETA
PostPosted: Wed Nov 14, 2012 12:13 am
Seconded wholeheartedly. However, if you're going for "as built" condition, you're restricted to something available between 1946 and 1950. The stereotype, for good reason, would be the Westinghouse E-2 single-note honker--the same one you hear running over Wile E. Coyote in Road Runner cartoons.
PostPosted: Fri Nov 16, 2012 11:49 pm
...and those ever present Leslie A-200s. Not sure how much overlap there would be, but 1950 is not too early for the Nathan/Airchime M-3, N-3, H-5 and M-5 models. Leslie also cataloged some "exotic" multi note horns as well -- E2-B3, etc. IIRC. However, I'd say ADM is correct in that most would have been delivered with single note honkers.
ETA
PostPosted: Tue Nov 20, 2012 5:34 pm
I took a few shots of PSRM's "ATSF 2098" cab last weekend. It will probably take a few days for me to get around to posting them. Doing a lot of Thanksgiving stuff . Based on the photo on our web site, it had a single note horn. This was originally Nevada Northern #103.
PostPosted: Wed Nov 28, 2012 9:21 pm
Here's some RS2 cab shots. Unfortunately, the cab is locked, so I had to take the photos thru the windows. Everyone is really busy getting set up for our North Pole trains, and didn't have time to dig up the key to the cab. It has been about 15 years since this engine has been run. If you want more, let me know. I should be able to access the cab after the first of the year.
