It is currently Mon Oct 19, 2026 3:31 am
 Post subject: 4501 Update 11-21-12 (No GPS)
PostPosted: Thu Nov 22, 2012 11:06 pm
Seeing how everyone like pictures and since I've now learned how to post them here, here are some more recent progress pics.
File comment: Overall view of the locomotive. The lead and trailing trucks will be removed soon.
File comment: The backhead with the mounting studs for the stoker assembly installed. Crown stays were being installed.
File comment: New crank pins and hubs on the #1 driver have been turned to finish size.
G. Mark Ray - TVRM
www.tvrail.com
 Post subject: Re: 4501 Update 11-21-12 (No GPS)
PostPosted: Thu Nov 22, 2012 11:11 pm
Here are three views of the stoker trough before it's installed into the tender tank.
File comment: 3/4 view of the rear and right side. A stainless steel liner was fitted into the replacement trough.
File comment: 3/4 view of the front and left side
File comment: View looking from front to rear.
G. Mark Ray - TVRM
www.tvrail.com
PostPosted: Thu Nov 22, 2012 11:17 pm
Finally, three more pics for your viewing pleasure. One shows the modifications to the coal bunker - we are adding coal gates in place of the old coal boards. The other two show work being done to the water column and associated valves.
File comment: Tender coal bunker showing modifications. Hardware is being added for new coal gates. A handbrake is also being applied.
File comment: Water Column, sight glass, tri cocks, and sight glass valves
File comment: The water column is stamped "4501" but when???
G. Mark Ray - TVRM
www.tvrail.com
PostPosted: Fri Nov 23, 2012 1:33 am
Great! Bill Purdie would be proud. Thank you for the update.
PostPosted: Fri Nov 23, 2012 9:46 am
Mark,
Thank you for the Thanksgiving gift...Great Pictures!
Amazing work being done in Chattanooga!
PostPosted: Fri Nov 23, 2012 11:03 am
Where's the GPS?
(runs and hides)
Mark Z. Yerkes
Amateur Rail Historian
PostPosted: Fri Nov 23, 2012 12:44 pm
Very impressive!
PostPosted: Fri Nov 23, 2012 9:43 pm
Stopped by today to get my first look at 630 since she returned, and to take a look at the work on 4501. Looking great, my thanks and props to all involved.
Brian Rogers
Knoxville TN
That which is seen is temporary, that which is unseen is eternal, therefore, focus on the unseen things.
