It is currently Wed Oct 28, 2026 12:50 am
PostPosted: Thu Oct 25, 2012 9:11 am
S. Weaver wrote:
p51 wrote:
... Good thing it's a pre-1900 design, you guys could have gotten into some serious trouble with the ATF had it been a design later than that for making the breech block workable (I doubt there's a breech ring, so the block is probably the part that would require registration as a destructive device, if it were a 1900 or later design).
It's all machinery to us, Lee ...
Pre-1900, huh? Now that gets me thinking about the Krupp 77mm under a tarp in the shop ...
Can you mount it on a flat car? (Runs and ducks for cover)
PostPosted: Thu Oct 25, 2012 7:52 pm
Kelly, the exact weight on the axle is 43,000 pounds. We could use that booster!
PostPosted: Sat Oct 27, 2012 3:54 pm
From a novice machinest, you guys are the BEST!! Such precision work is hard to come by in this day and age!
PostPosted: Sun Oct 28, 2012 11:33 pm
Yes, until someone from the ATF shows up and throws everyone who worked on it into federal prison for several years and hits you with a nasty fine, especailly since you were doing it for a fee for someone. I can promise you the feds won't care a bit then.
Just some friendly advice. You're fine with anything pre-1900 in design, but before you work on any breech-loading in the future, you should have someone familiar with the laws look up if it's smart to do so. For example, if someone came in with a WW2 gun, it could get very ugly if you work on the wrong part...
Lee Bishop
