It is currently Sat Oct 31, 2026 12:54 am
 Post subject: Wheel gage for 24" mining railroad equipment
PostPosted: Fri Sep 07, 2012 12:28 pm
Does anyone have or know a souce for a wheel gage for 24" gage mining railroad equipment?
Greg
Greg Ramsey
Roundhouse Track Services,
Volunteer:
Travel Town Railroad Museum
Nevada Southern Railroad
 Post subject: Re: Wheel gage for 24" mining railroad equipment
PostPosted: Fri Sep 07, 2012 2:36 pm
I think I do in an old American Mining Institute book.
Are you starting with any equipment or rail already laid, or are you wanting a place to start from scratch?
Establishing a standard back to back to use is always a compromise between the gauge (actual), any gauge widening on the curves, the radius on the rail head, the flange way width that you can find on frogs, the check gauge distance, that you can find on guard rails, also helps. After you get all that, then you can look at the profile and size of the radius at the to tread/flange interface, the wheelbase of the equipment, and thats just about all you have to use to make a determination.
I'll see what I can dig up.
PostPosted: Sat Sep 08, 2012 7:07 am
I'm not aware of any gage used to check wear, etc on the wheels... in the older days there did not seem to be any clear standard like the MCB standards on larger cars. I'd suggest picking one 'standard' in terms of profile, check gage, etc. and stick as close to it as you can... you may want to consider using what your biggest, hardest-to-change locomotive is using and make everything else match as carefully as possible.
PostPosted: Sat Sep 08, 2012 3:30 pm
I would like to find a copy, in print or online, of the American Mining Congress wheel and track standards. We are fortunate that many manufacturers now and historically have cataloged their products in enough detail to replicate such information. Here are some google book sources you may peruse:
C.S. Card Mine Haulage and Handling Equipment Catalog (1940)
http://books.google.com/books?id=xIidnRgBAcYC
The Mining Catalog (1921)
http://books.google.com/books?id=j2kKAQAAMAAJ
Bethlehem Steel Mine and Industrial Trackwork Catalog
http://books.google.com/books?id=tXIG8xq6KPgC
regards,
O. Anderson
moderator for 18 to 23 inch gauge railway discussion
http://groups.yahoo.com/group/18inch
