It is currently Thu Oct 29, 2026 10:21 pm
 Post subject: Looking for drawings of Baldwin class 10-34E 2-8-0 circa1883
PostPosted: Sun Sep 02, 2012 11:48 am
We are hoping to built a model of a Northern Pacific Class F 2-8-0 which was built in 1883. So far we haven't found any drawings except a very brief one from around 1907 when they were re-boilered and made into 0-8-0s. So, now we are hoping to just find good drawings of the Baldwin class 10-34E, which would give us all the basic dimensions.
Thanks,
 Post subject: Re: Looking for drawings of Baldwin class 10-34E 2-8-0 circa
PostPosted: Sun Sep 02, 2012 11:09 pm
Baldwin class'.
There were many different locomotives built to the class 10-34E , even in 1883 there could be a couple of very different locomotives built within that same class 10-34E .
You will need to look it up in the Baldwin sales records (by the Baldwin CD from"Taplines": http://taplines.biz/Baldwin-Locomotive- ... 29567.aspx) and find out what "drawing" it was built to, then look up its sales order info then you are just about ready to try to locate the builders drawings.
Prepare yourself, there is a 95% chance that you will not find those drawings, or any drawings, because they probably do not exist, but most times the side elevation sheets can be located, these would be in Degolyer if they exist.
Your best bet for finding Baldwin drawings is to locate the RR archives, for the RR that bought and owned the locomotive when it was new. Those archives will most times have more info on any one specific Baldwin locomotive than the various Baldwin collections have presently.
Check SMU's collections to see if the specification order sheets have been posted yet, some have (about 30% are still not completed): http://digitalcollections.smu.edu/cdm4/ ... CISOPTR=32
This will be a long process so be patient.
What RR was it built for, delivery date, what was the Sales Order number, what gauge, and what road number did it carry when ordered and delivered?
Those answerers will help other to help you here on the forum.
Best of luck to you!
PostPosted: Mon Sep 03, 2012 2:16 am
May not be of huge help but there is an 1899 Alco NP Y-class 2-8-0 at the Civic Center in Butte, MT. It might provide a little direction. I believe it is the last NP 2-8-0 left.
PostPosted: Mon Sep 03, 2012 7:16 am
Unfortunately, the F class is much older and very different from the Y that still exists. Also, the F is quite different from the later F-1 that came out in 1888. She's lighter, too light on her feet in fact, with a factor of adhesion of only 3.85. A real pretty engine, but not successful for what they were designed for. These were converted to class G 0-8-0 switch engines with new boilers in the early 1900's.
Here's the Baldwin spec sheet
NP Cl F 336, 340-344 2-8-0 Baldwin class 10-34E
10 wheels, E=8 drive wheels, (34/2 +3)=20" cylinder bore
BUILT: 9/16/82
WHEELBASE: 14'0" rigid; 21'6" engine; 49'2" engine and tender
DRIVERS: 49" diameter with 43" diameter centers, Krupp crucible steel
tires shrink-fitted
Flanges on #1 and #4; no flanges on #2 and #3
ENGINE TRUCK: 29" cast wheels, cast iron swing bolster
WEIGHT: 96,000 lbs on drivers; 108,000 lbs engine
BOILER: 60" straight with 266 steel tubes 12'8" long and 2" diameter
Planished jacket with brass bands
32"diameter steam dome, painted, no beads on 341 and after
27-28"diameter sand box, painted, no beads on 341 and after
Injectors: Freidman #8-10 R & L and BLW check valves R & L
Throttle: balance, dome
Colbaugh lamp and flag holders on both sides of the smokebox
Wood running boards with angle iron headers
Lamp shelf: cast iron, painted;
Headlight step
Headlight: 23" reflector; to burn kerosene; painting #4
Handrail: iron colm placed radialy
Bell stand: iron, large
FIREBOX: steel, 103" long. 42.875" wide and 53.5"F and 50.5"B,
combustion chamber 5"
SMOKE BOX" 6' longer than usual, no pocket or discharge pipe
Stack: diamond on 336 and 340, 18; as per blue print, 17"
FRAME: Solid, bolted braces
CYLINDERS: 20" bore x 24" stroke. Cast steel crossheads and steel
guides
PILOT: Wood cos style, no steps, oak bumper, no bumper blocks
Flag fixtures: iron, on bumpers
CAB: Ash, painted, with two seats with cushions
TENDER: 8-wheel with oak frame, 3600 gal, bill 482
Trucks: 33" wheels; heavy sq frame; semi-elliptic springs; brakes
on both trucks
Single safety chain
Drawhead centers 29" and 33.5" above rail
PAINTING: black, no striping
On tank: Northern Pacific
Back of tank #2, sand dome #3 and side collar #4: 461-466
Cab panel: NPR
Thanks for the help so far, eventually we'll get this narrowed down!
PostPosted: Tue Sep 04, 2012 7:17 pm
The F class is, hopefully, his next project. To give an idea of what his models look like, here's the latest. Tim Muir has just about finished the F-1 Class NP 2-8-0 in the 1890 appearance. I am a beta tester.
He did #485, which was featured in a nice drawing in November 1958 Model Railroader. He's done several later versions, circa 1910 and 1940 appearances of other F-1 engines, with accurate modifications. This one's my favorite! I should mention, these are designed for Microsoft Train Simulator and Open Rails.
These shots are on my Virtual railroad, running Open Rails.
And last, with a bit of Photoshopping, how it appears in black and white at the logging site. Imagine famous logging photographer Darius Kinsey with his big camera, set up to do another locomotive portrait.
We are still searching for the elusive drawings!
Keeping history alive in simulation.
